  • New Member
  • Member For: 11y 1m 7d
Posted
Fg xr6-t has been recently lowered with SSL fronts and SSSL rears. Had a look underneath and the rear is sitting on the bump stops. Is that bad to be riding on bump stops? Should I take the bump stops off completely? any opinions would be muchly appreciated.
Cheers.
post-85081-0-02647900-1440761952_thumb.j
post-85081-0-30624000-1440762280_thumb.j
  • Legacy Donating Member
  • Member For: 18y 11m 23d
Posted
Just cut them down a bit ,or you can buy shorter ones,
I got some shorter ones from Pedders
Even on a standard car they are very close.
  • Member For: 13y 5m 15d
Posted
I have ssl on the rear and after a few weeks cut the bump stops at the first knuckle (or whatever it's called) and doing so dropped my car by a mm on one side an 2mm on the other so they must of been 'just' touching
  • New Member
Posted
yeah today they were cut at the first knuckle and it still seems to be still sitting on the bump stops. Maybe they should be cut at the next knuckle from that or completely remove them?
  • Sandtrap Motorsport
  • Member For: 17y 9m 28d
Posted
I had my FG sitting on bump stops, this supposedly pre-loaded my IRS, resulting in this occurring .... Luckily warranty covered it for me
  • Like 2
  • New Member
Posted
I had my FG sitting on bump stops, this supposedly pre-loaded my IRS, resulting in this occurring .... Luckily warranty covered it for me78d7d9fb314fa89bd436617b1a99819d.jpg
What was your suspension set up? Also how did your issue get fixed under warranty when they don't come from factory sitting on bump stops?
  • Member For: 18y 9m 29d
Posted
He also raced it hahaha
Assuming that is [POKE] I'm looking at
Posted
Bingo Steve haha
I had good rapport with my ford -- I guess with the Economy these days, it wouldn't be possible
Tein coil overs, rings removed, base machined on the rear.
Camber kits F&R,
Adjustable swaybars
Super pro solid centre & turbo sides (post diff tear)
But it sat low - thus the strain on the diff
  • Member For: 15y 8m 3d
Posted
Why a solid firm centre and stock sides now? That is the opposite to what you actually want for longevity with a bit of power. Surprised you haven't had a bolt snap with that setup!
Don't think that "pre load" theory is correct either... first I've heard of that!
