hawlass Silver Donating Members 1,161 Member For: 16y 5m 20d Gender: Male Location: left right out Posted 05/07/15 07:48 AM Share Posted 05/07/15 07:48 AM Ok, took a couple of pics in the dark, hope it helps a little.This is taken from the rhs looking at the silicone joiner coming down off the turbo, joining onto the 90 alloy bend and going forward over the crossmember ( not under! ) This next pic is taken looking down from above and shows the next silicone 90 degree joiner that links the black alloy pipe in the last shot to the silver alloy 180 degree bend which goes out towards the rhs , around the radiator and comes back to meet the intercooler. 1 Quote Go to top Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 16y 5m 20d Gender: Male Location: left right out Posted 05/07/15 07:51 AM Share Posted 05/07/15 07:51 AM And a pic off the web of how it meets the cooler. the pipe is silver on mine but black in this pic, just another 'benefit' of the rapid kits - nothing matchs! 1 Quote Go to top Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 8y 9m 24d Gender: Male Posted 05/07/15 09:11 AM Author Share Posted 05/07/15 09:11 AM Thanks heaps for that, very helpful. Quote Go to top Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 8y 9m 24d Gender: Male Posted 05/07/15 09:29 PM Author Share Posted 05/07/15 09:29 PM It's a b series and that's not where that pipe should goI see your other thread Re exhaustSounds like the car has already been tuned with all of the hardware that's been fitted .... Unless it's hitting boost cut about 4000rpm ?Regarding hitting boost cut with the 4" dump fitted, shouldn't the actuator still open the wastegate at the same pressure as before? I wouldn't have thought there would be an issue. Quote Go to top Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 29d Gender: Male Location: Adelaide Posted 05/07/15 10:11 PM Share Posted 05/07/15 10:11 PM (edited) On an old school turbo car yeh Not on a falcon as the boost is referanced against load and factory is set to 5psi and allows boost spikes only for a short time before the ecu will close the throttle A higher flowing exhaust will cause greater boost pressure and needs to be tuned to suit This is a dyno graph of a BF xr6 T with a 3.5 inch exhaust and 4inch dump fitted but a stock tune Check the boost Double the boost and we didn't even let this cut as we knew what we were expecting so we pulled the run, this was coming in for a tune to be rectified for this issue only Edited 05/07/15 10:13 PM by Womend Bellbat 1 Quote Go to top Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 8y 9m 24d Gender: Male Posted 05/07/15 10:24 PM Author Share Posted 05/07/15 10:24 PM On an old school turbo car yehNot on a falcon as the boost is referanced against load and factory is set to 5psi and allows boost spikes only for a short time before the ecu will close the throttleA higher flowing exhaust will cause greater boost pressure and needs to be tuned to suitThis is a dyno graph of a BF xr6 T with a 3.5 inch exhaust and 4inch dump fitted but a stock tuneCheck the boostDouble the boost and we didn't even let this cut as we knew what we were expecting so we pulled the run, this was coming in for a tune to be rectified for this issue onlyThanks for the explanation, I haven't had a turbo since a Silvia about 7 years ago, I guess things have changed a bit since then! Better get it tuned asap. 1 Quote Go to top Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 29d Gender: Male Location: Adelaide Posted 05/07/15 11:19 PM Share Posted 05/07/15 11:19 PM Where are u located and we can point u in the direction of a reputable workshop to tune your car Quote Go to top Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 8m 10d Gender: Male Location: Zombie Birdhouse Posted 05/07/15 11:32 PM Share Posted 05/07/15 11:32 PM (edited) Gold Coast - some guys on here use these guyshttp://www.hi-torqueperformance.com.au/about.htmlOr Brisbane Southside - My tuner of choice in Brisbane areahttp://www.eliteauto.com.au/Give them both a call. Edited 05/07/15 11:40 PM by Buf-Phoon Quote Go to top Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 28d Gender: Male Posted 06/07/15 02:24 AM Share Posted 06/07/15 02:24 AM Dat pipe! Quote Go to top Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 8y 9m 24d Gender: Male Posted 06/07/15 07:05 AM Author Share Posted 06/07/15 07:05 AM Where are u located and we can point u in the direction of a reputable workshop to tune your carI'm on the Gold Coast, so Brisbane would also be ok.Gold Coast - some guys on here use these guyshttp://www.hi-torqueperformance.com.au/about.htmlOr Brisbane Southside - My tuner of choice in Brisbane areahttp://www.eliteauto.com.au/Give them both a call.Thanks, the first one told me I would need to do the waste gate flapper upgrade, but at bare minimum you would need to replace the injectors and purchase a SCT4 Flashbox. The second just said I can get the SCT4 flasher and do the tune. I'm guessing the SCT4 is a definite requirement and the x3 wouldn't do? Also, is there different versions, or they're all the same. If so I guess I could get one from the US on ebay? http://www.ebay.com.au/itm/261827668894 Quote Go to top Link to comment Share on other sites More sharing options...
