pac23 Member 103 Member For: 13y 1m 30d Gender: Male Location: Sydney Posted 23/12/14 04:30 AM Share Posted 23/12/14 04:30 AM My turbo is starting to develop a noise in spin down when I shut the car off.. Pretty sure I might not see the turbo for much longer.. Currently setup:1000hp rapid cooler setup.60lb DekasWalbro 255 intank4inch dump and twin 2.5 xforce12psi turbosmart actuator and wastegate flapper mod.I want to just replace turbo for now as can't afford much more..Later kpm intank and 1000cc injectors and probably eflexWhat turbo would you suggest and what should I see on pump fuel with current setup on either turbo??? Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/ Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 19d Gender: Male Location: Adelaide Posted 23/12/14 04:37 AM Share Posted 23/12/14 04:37 AM gtx should see 350 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1518934 Share on other sites More sharing options...
pac23 Member 103 Member For: 13y 1m 30d Gender: Male Location: Sydney Posted 24/12/14 04:15 AM Author Share Posted 24/12/14 04:15 AM Have hear fitting the gtx is a bit of stuffing around.. Is the precision in the same boat?? Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519074 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 1m 14d Gender: Male Location: Gold Coast Posted 29/12/14 11:41 AM Share Posted 29/12/14 11:41 AM ^^^ yep. Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519764 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 19d Gender: Male Location: Adelaide Posted 29/12/14 12:39 PM Share Posted 29/12/14 12:39 PM (edited) 1 hr turbo off. 1 hr turbo change over to housing and set actuator. 1hour to put it back on. holes are cast in a different place to the stock gt. can modify the actuator bracket or get a universal actuator bracket or the turbo will be on a 15-20 degree angle. still works. still works fineGTX FTW Edited 29/12/14 12:41 PM by Bizkets is fat? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519780 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 10m 6d Posted 29/12/14 02:11 PM Share Posted 29/12/14 02:11 PM If your wanting a comparable turbo to the precision..then you'd be looking at the gtx3582.76 not in the same league 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519787 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 2d Gender: Male Posted 29/12/14 10:02 PM Share Posted 29/12/14 10:02 PM I don't get why the GTX3576 gets so much air time....like mentioned there are turbos that will spool the same but make allot more power. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519804 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 19d Gender: Male Location: Adelaide Posted 29/12/14 11:15 PM Share Posted 29/12/14 11:15 PM Maybe people like the 300-350 mark with more torque and dont want to much power breaking sh*t. Gtx holds up the top end where the standard gt falls over at 5000rpm. Also a option to go e85 and hit that 400rwkw mark for power cruise/drags/cruises. Stigmata got 446rwkw on e85 on a gtx76 so there is some potential out of the little turbo. When you get your car going karl ill pop down a.I.r and have a watch. Hopefully ill have mine down to. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519809 Share on other sites More sharing options...
GeGe6 Donating Members 1,980 Member For: 12y 11m 18d Gender: Male Location: Perth, SOR Posted 29/12/14 11:16 PM Share Posted 29/12/14 11:16 PM I don't get why the GTX3576 gets so much air time....like mentioned there are turbos that will spool the same but make allot more power.That cost what? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519810 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 30d Gender: Male Location: NOR Perth Posted 30/12/14 12:06 AM Share Posted 30/12/14 12:06 AM ^^^And modifications to make it fit? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89785-gtx3576-or-precision6235/#findComment-1519816 Share on other sites More sharing options...
