  • Inactive Members
  • Member For: 12y 9m 28d
Posted
hi all
About 4 months ago I started modifying my 2004 ba xr6 turbo, starting with exhaust an high flow cat, than I got upgraded injectors installed an tuned ( siemens deka 60lb) I also got my gearbox rebuilt by MVAutomatics stage2, it didnt make much power with the first tune (203rwkw) my tuner said I needed heavy duty valve springs so I bought plazmaman valve springs and got them installed and retuned....PROBLEMS THAN STARTED) the car made (249rwkw) but was playing up.....the car wouldnt boost properly and after hitting boost felt like it was dropping a cylinder if not too, would run rough for 10 or so seconds than run fine, took it bak to my tuner an he said ok it needs upgraded wastegate and actuator plus boost controller, so going with his advice we went ahead with all that not stinting on anything...got all that installed and retuned again it made (279rwkw) current on 15 psi but had the same problems there so took it bak again and said not right, my tuner checked the tune again and found that the torque management setting was causing the boost issue so he turned that off and fixed the boosting issue, huts 15.5 psi had and holds fine but still have the problem after boost dropping cylinders or what ever its doing, Ive rang turbosmart too see if it was a boost issue, nope tested all that, we have changed lifters, dudnt fix problem, changed standard valve springs back over still does it, pressure tested motor, fuel system, air tested valves, pulse tested injectors, spark tested coils, plugs and coils are brand new and plugs been gapped to.08??? the're at a loss so am I..HELP PLEASE
  • Legacy Donating Member
  • Member For: 16y 10m 25d
Posted (edited)
Are they factory coils?
Edited by sexual harrassment panda
  • Member For: 13y 4m 29d
Posted
Sounds like spark or timing bud. I would start with checking your timing as the problems started after your tuner played with springs. And he may have removed the timing chain in order to gain access to the springs.
  • Member For: 16y 15d
Posted
Had the same issue with my BA. Had what felt like valve springs took it to two Sydney tuners and both diagnosed valve springs. Put in new springs all good till I got it tuned only 12 psi and after a few big WOT and stop it would idle funny like before and it did it on the dyno. It wouldn't do it until you had done a few hits both street and dyno . Checked everything got told from valve spring guy that its lifters but tuner was positive it was the new valve springs. Never found out I put it back to stock and it never did it again.
Posted
Sounds like valves springs mate. And putting the stock springs back in would've proved nothing as they will float at modest boost levels too.
IF it wasn't springs, there's a few areas of the tune which can causes this exact issue.
  • Member For: 12y 10m 17d
Posted
Ello, search "turbo early discharge" for my full post. Had a similar problem, now fixed!. To test this, remove the concertina pipe. Take it for a run
