Adamfiza80 Member 74 Member For: 12y 1m 23d Gender: Male Location: Newcaslte Posted 12/11/13 01:52 AM Share Posted 12/11/13 01:52 AM Anyone tell me what power I should theoretically be able to obtain on e85 with these bosch 1000cc inj on my fg. I have a Process West new surgy with twin dw300 pumps and standard fuel rail. Was told my duty cycle was about 95% on e85. My dyno read out shows @lambda 0.9 across entire rev range. Boost was 16psi and peak midrange at 18 then backed down to 16psi. Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 21d Gender: Male Location: Adelaide Posted 12/11/13 01:56 AM Share Posted 12/11/13 01:56 AM 1000's on e85 on lambda .80 should see 460rwkw at 90% DC maybe a touch more DC If your toping out at 95% DC at lambda 0.9 u have two issues One is farking lean Two the slopes seem to be hugo mungusly wrong 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439510 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 1m 23d Gender: Male Location: Newcaslte Posted 12/11/13 02:05 AM Author Share Posted 12/11/13 02:05 AM I was only told that it was at 95%. Had no proof. Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439513 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 21d Gender: Male Location: Adelaide Posted 12/11/13 02:20 AM Share Posted 12/11/13 02:20 AM I know one very well regarded sydney tuner who goes as lean as 0,90 on e85 but also has a few decent titles against his workshop but that's a bit to lean for me ( not saying it doesn't work )95% DC should be the most upper limit of any injectors range to work well 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439520 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 1m 23d Gender: Male Location: Newcaslte Posted 12/11/13 02:35 AM Author Share Posted 12/11/13 02:35 AM Yeah im thinking of upgrading injectors as they were purchased way back when my goal was only 300rwkw. Since then I have a built atomic built engine so my power hunger changed. Only had car for 2 months tuned and I want 2 get the a bit more out of my duel pump surgy. Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439525 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 15d Gender: Male Location: OZ Posted 12/11/13 02:35 AM Share Posted 12/11/13 02:35 AM 1000's on e85 on lambda .80 should see 460rwkw at 90% DC maybe a touch more DC If your toping out at 95% DC at lambda 0.9 u have two issues One is farking lean Two the slopes seem to be hugo mungusly wrongNothing to do with the slopes. Either the ethanol content is much higher than 85%, the cylinders / head / cams have had some serious work, the fuel pressure is set wrong, turbo is amazing, they're not actually 1000cc etc etcThat duty at that psi is odd....check fuel pressure. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439527 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 1m 23d Gender: Male Location: Newcaslte Posted 12/11/13 02:54 AM Author Share Posted 12/11/13 02:54 AM Rodger that. Car has the PW stage 1 fuel kit which includes new pressure regulator. Tuner did the full install so I mite mention the pressure idea to him. Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439541 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 12d Gender: Male Location: Loitering in SEQ Posted 12/11/13 02:55 AM Share Posted 12/11/13 02:55 AM I dont know feck all about the technical side of things but we've made 600kw on e85 with 1000's 2 Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439542 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 9m 6d Gender: Male Posted 12/11/13 03:03 AM Share Posted 12/11/13 03:03 AM (edited) Veva went 500 on 1000's with e85 at that lamba, may have even had a bit of e98 in there and I'm sure boost was way more than 18psi,maybe ~23-24psi.ID1000's should be good for over 500, at least I hope they are as these will be the injectors I purchase when I fit the GTX. Edited 12/11/13 03:04 AM by rednose Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439547 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 12d Gender: Male Location: Loitering in SEQ Posted 12/11/13 03:12 AM Share Posted 12/11/13 03:12 AM Think it might of been e98 when he ran out at 500. @ 25psi & between .8/.85 lambda we were seeing 600kw & that's on multiple dynos 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86749-bosch-1000cc-inj-max-power/#findComment-1439550 Share on other sites More sharing options...
