AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 17d Gender: Male Location: WA Posted 26/07/13 01:59 PM Posted 26/07/13 01:59 PM Correct
BlueOvalPower Member 42 Member For: 13y 2m 21d Gender: Male Posted 29/07/13 02:14 PM Author Posted 29/07/13 02:14 PM (edited) Is there much work involved fitting them into the original cradle? As much as id love a drop in plug and play I dont mind a little bit of work if the pump kit comes with all parts needed to fit it up to the old cradle.and yah even though we dont have E85 here, id still want it compatible for when we do finally get it up this way. Edited 29/07/13 02:15 PM by BlueOvalPower
AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 17d Gender: Male Location: WA Posted 30/07/13 08:27 AM Posted 30/07/13 08:27 AM Not sure as I have never fitted on to an Fg. But the club sport one I did was essy
KPM Motorsport Member 968 Member For: 20y 11m 16d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 30/07/13 11:00 PM Posted 30/07/13 11:00 PM Is there much work involved fitting them into the original cradle? As much as id love a drop in plug and play I dont mind a little bit of work if the pump kit comes with all parts needed to fit it up to the old cradle.and yah even though we dont have E85 here, id still want it compatible for when we do finally get it up this way.Hi Blue OvalYou will find if you replace the pump only you will have 2 problems.High fuel pressures and wiring not handling currant draw.Both these 2 items will dramataclly lower the fuel delivery from your larger pump.If you are interested we can supply a total package which includes correct plug and play/wiring relay kit, high flow fuel presure regulator and correct intank canister. This will ensure your system is a direct replacemant without any hassles.
BlueOvalPower Member 42 Member For: 13y 2m 21d Gender: Male Posted 31/07/13 09:01 AM Author Posted 31/07/13 09:01 AM Yah sounds good to me KPM, should of bought it with the injectors I just got from you lol
KPM Motorsport Member 968 Member For: 20y 11m 16d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 31/07/13 10:13 AM Posted 31/07/13 10:13 AM Yah sounds good to me KPM, should of bought it with the injectors I just got from you lolLet me know if we can help in any capacity.RegardsDavid
jayjaybrid Member 98 Member For: 15y 3m 15d Gender: Male Location: Albury Posted 24/08/13 04:24 PM Posted 24/08/13 04:24 PM does any 1 know what size resister should be used with 1 of these pumps for correct pressure , sozz to try undercut kpm as this is my quick fix til I can afford and utilize your big dual banger
AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 17d Gender: Male Location: WA Posted 25/08/13 09:03 PM Posted 25/08/13 09:03 PM It won't be that simple, as pressure and flow will change over the whole rev range. You could grab yourself a Flash tuner and try tune the pump to your engine on the road, then if you still cant get it right then you'll need to modify your fuel rail reg. 1
Besty221 Member 18 Member For: 13y 1m 13d Gender: Male Location: Cobar Posted 26/08/13 04:35 AM Posted 26/08/13 04:35 AM Go on rapid systems they sell a big Bosch fuel pump with cradle for $200 rated 800hp
