AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 5d Gender: Male Location: WA Posted 14/07/13 01:00 AM Posted 14/07/13 01:00 AM (edited) When opening these holes up, ensure you caress them gently with the die grinder. If you don't the plastic will chip (big chips) and your hole will look like you opened it up with a hammer.I have had hoses blow off while driving to very important lunch breaks, so I glued all my joins that sit inside the bumper. You dont need a hose blowing off while being charged premium rates for being on the dyno. This is a personal thing, but it works!This is how I worked the air box around the cooler pipe. I left the snorkel in there but trimmed it as you can see. I cant see any hot air being drawn into the air box while sitting at 100km/hr1000hp cooler? I couldn't see it if I triedThis electric die grinder worked a treat and as I see it, it is a must for this install.I hope this helps some one.Just had an enquiry for more info. So here are some more pics.BeforeAfterBeforeAfterBeforeAfterAfterAfter- removed to clear the hot side pipe.BeforeAfter- for some reason the hole was to small. Hint hint nizpro. 10mm drill bit and sensor safe silicon does the trick.After- I removed the steel to clear the cooler end tank.After- same on the passenger side.After I cut the bolt on the condenser bracket. (6mm bolt of no use)After- you can see on the passenger side I removed steel out of the crash bar to clear the cold side cooler hose.BeforeAfterAfter- I put an extra bit of silicon hose there to protect it from a rub through.After I moved the fan plugs out of there socket.After- you can see in this pic that there is no centre support. I cut it out, and you can see the burr marks on the uprights if you zoom in.Also buy a can of no primer required kill rust mat black in a spray can. Spray all the mods you make, to seal the steel, to prevent rust and make it look like a professionals job.All the best. Edited 15/07/13 11:52 AM by Dagabond 1
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 2d Gender: Male Location: Melbourne Posted 14/07/13 01:47 AM Posted 14/07/13 01:47 AM because im awesome
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 2d Gender: Male Location: Melbourne Posted 14/07/13 01:57 AM Posted 14/07/13 01:57 AM im adminI can fix anything hereright dags? 1
STAINLESS again plz You've changed man.... Legacy Donating Member 8,142 Member For: 15y 9m Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 14/07/13 02:47 AM Posted 14/07/13 02:47 AM Bitchmod now edit op so pics work. This is a good thread and should be tidied. 1
ms700 Moderating Team 10,170 Member For: 23y 7m 27d Gender: Male Location: Sydney Posted 14/07/13 02:53 AM Posted 14/07/13 02:53 AM thread tidied upcept for trents postscause, well, he is awesome 2
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 2d Gender: Male Location: Melbourne Posted 14/07/13 03:00 AM Posted 14/07/13 03:00 AM this guy knows ^ 2
AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 5d Gender: Male Location: WA Posted 14/07/13 05:57 AM Author Posted 14/07/13 05:57 AM Thanks ms700. The thread was a real mess before you fellas cleaned her up. I have more photos so if some one needs them, don't hesitate to ask.
ms700 Moderating Team 10,170 Member For: 23y 7m 27d Gender: Male Location: Sydney Posted 14/07/13 06:11 AM Posted 14/07/13 06:11 AM all good, its a great informative thread that im sure people will find very useful.
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 2d Gender: Male Location: Melbourne Posted 15/07/13 11:30 AM Posted 15/07/13 11:30 AM mate got to hand it to ya, you done a good job tackling this. its a big cooler.theres a reason why I paid nizpro to do it ahhahwell done with the pics!!!!!! 1
AdamIan69 Legacy Donating Member 401 Member For: 13y 5m 5d Gender: Male Location: WA Posted 15/07/13 11:43 AM Author Posted 15/07/13 11:43 AM Cheers. There was a few tears, and the missus missed our baby checkup lol. But I ensured her it was worth it.
