Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 3d Gender: Male Location: Perth Posted 01/06/13 04:56 AM Share Posted 01/06/13 04:56 AM Oh dear Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 13y 7m 22d Posted 01/06/13 05:13 AM Author Share Posted 01/06/13 05:13 AM Oh dear in deed, lucky im a clever f#%ker and checked vin/engine number with ford. Scary to think how many times try have done it to others. Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 5d Gender: Male Location: Sydney Posted 01/06/13 05:25 AM Share Posted 01/06/13 05:25 AM that's fucct mate.. slimey chunts!What did you say to them? Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 13y 7m 22d Posted 01/06/13 06:50 AM Author Share Posted 01/06/13 06:50 AM Long long long conversation but the gist was give me my money back or I'm taking u to the cleaners. Cash is back in the bank today and motor is still at my house..... Doubt they will pick it up as its already cost them $300 to get it To me Link to comment Share on other sites More sharing options...
Quasi XR6T Member 153 Member For: 11y 2m 26d Gender: Male Location: Canberra, Australia Posted 01/06/13 07:24 AM Share Posted 01/06/13 07:24 AM (edited) Lowlife pricks. At least you got your money back....unbelievable. I was thinking that doing what you MEANT to do was definitely the best option money wise. However, what they did is something at the back of my mind, that I wouldn't end up with what I bought.Still, there must be a reputable mob out there that have what you want.http://www.ebay.com.au/itm/BF-MKII-FORD-FALCON-XR6-TURBO-COMPLETE-ENGINE-CONVERSION-KIT-GENUINE-RECYCLED-/271215077375?pt=AU_Car_Parts_Accessories&hash=item3f25ada7ff Edited 01/06/13 07:29 AM by Quasi XR6T Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 13y 7m 22d Posted 01/06/13 07:40 AM Author Share Posted 01/06/13 07:40 AM Yeh few getting around on eBay, really want car to be a little different and have the fg setup. Price was too good to pass but that's obviously why.... Haha LPG motor = about $500 worth. So $2000 profit for them... Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 5d Gender: Male Location: Sydney Posted 01/06/13 07:48 AM Share Posted 01/06/13 07:48 AM I have found these guys to be goodhttp://www.macarthurautoparts.com.au/Fairly well organised bunch, everything has a place and 9/10 they usually have just the part you need.. 1/2 the price of some of the gear at the other joint. that's what I have found anyway, each to there own 2 Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 13y 7m 22d Posted 04/06/13 08:08 AM Author Share Posted 04/06/13 08:08 AM Another fg long on its way, 53000km this time..... Have confirmed vin etc with ford so hopefully this one is a genuine turbo motor haha Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 13y 7m 22d Posted 25/07/13 10:58 AM Author Share Posted 25/07/13 10:58 AM ok so finally got engine into car, thought I'd throw up the pics and brief run down on whats needed to fit an FG long into a BA/BF.please note, this is a big job for someone with little experience/tools. this is just a guide of how I went about the change of engines, others may have different opinions but this work for me.parts needed: ba/bf sump ba/bf oil pickup sump gasket inlet/exhaust manifold gaskets spigot bearing (if manual) new fluids1) pull old engine out.....remembering to label all wiring etc. funny enough this link actually helped.... http://au.answers.yahoo.com/question/index?qid=20110701180001AArtHPt2) place turbo, inlet manifold etc etc etc onto FG engine ( straight bolt up no mods needed), I did remove the old FG water lines etc and used mine., there is also an extra coolant line coming out of the blocks back right passenger side, I used a spare sensor I had from the old engine and screwed it in as is not needed for the ba/bf.3) now its time to turn engine over (carefully) to access the sump, be very cautious to check which sump you get as they changed the sump style at the end of 2005.mine was the one with the full gasket where as after 2005 they went with half moon gaskets.undo all sump bolts and remove old sump.4) time to replace oil pickup with a bf version, one of the main cap bolts need to be moved up and the one with the thread moved down to enable pickup to be bolted on, retighten to 90lb with a torque wrench. make sure to use the oring from the FG pickup end that attaches the oil pump.5) since the FG's sump is reverse to the BA/BF the dipstick needs to be moved to the front of the block. there is a cap filling the hole where the ba/bf dispstick goes. grab something that fits into the hole and punch out the cap. then find a bolt to fit the old hole of the disptick and thread it in (tap and die set needed). you will also have to make a small adjustment (ie cut a peice out) of the windage tray to suit new dipstick path.6) next fit the new sump to the block, we noticed that the windage tray did touch but with a little bit of convincing it fitted nicely, a good point would be to check where your pickup sits in the sump as you dont want it touching the sump or too high above either. 7) the engine mounts are different on the FG to BA/BF so a small modification to the block is needed to fit the drivers side mount. we simply trimmed the lug that was sticking too far out which stopped the BF mount sitting flat. 8 ) engine is now ready to go back in, be aware of what engine you have purchased, mine was an auto so I needed to purchase a new spigott bearing.All done 9) engine will run with the same tune previously installed but will definitely need a touch up, mine is running rich as and extremely lumpy at idle (no vac leaks, so will assume its the tune untill next week when I visit my tuner.hope this helps anyone attempting this job, remember its not a straight swap and will require someone with a decent mechanical mind to complete. please dont take this "how to" as gospel and I take no responsibility if you stuff something up. 3 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m 2d Gender: Male Location: Probably above atmospheric pressure Posted 25/07/13 11:06 AM Share Posted 25/07/13 11:06 AM (edited) LikeMainly because I may need it one day! Edited 25/07/13 11:07 AM by -SteveR- Link to comment Share on other sites More sharing options...
