  • Legacy Donating Member
  • Member For: 21y 4m 14d
Posted
Guys,
I have put an air to oil tranny cooler, on by BF, (ZF) but have noticed the thermo fans are coming on far more often since the install.
Does anyone know what the ideal tranny oil temperature range is?
Would my tranny oil getting hot trigger the thermos to go off..?
Is there a temp sensor for the tranny oil?
If so, can a run of the mill obd11 scan tool read the tranny oil temp?
I'm sort of worried about getting air flow to the cooler when stuck in traffic on hot days.
Any input is appreciated.
Cheers
  • Member For: 17y 1m 10d
Posted (edited)
Guys,
Cheers
Hi boost69
My logs show zf trans temps around 80Deg C are normal for an FG.
I had an external cooler installed on the zf today, and the temp now sits around 55-65DegC @ 25C Ambient temp, acording to the DashDaqXL logs.
Edited by SilkG6ET
  • Member For: 20y 7m 20d
Posted
Have a look at the last few pages of the link above, if anything your trans temps will be way cooler than before. Warmest I have seen is 85degrees after a thrashing at the lights, coolant temp was 99. And it dropped back to the 70s once at 70kph for a few minutes.
My cooler is also behind the foglight.
Posted
Thanks for the reply guys.
The only thing that worries me is that I have the trans cooler laying flat, inbetween the intercooler and the bumper/under tray.
I have also cut a hole in the under tray to try and get some better airflow.
Not sure if the cooler laying flat is getting optimal air flow.
I'm thinking about repositioning it.
You guys think it's ok where it is now?
  • Member For: 15y 11m 26d
Posted
My trans oil sits at around 92degrees at normal driving with no trans cooler. Getting my zf serviced on Friday though. Been a bit funny at cold lately not wanting to change gears till I'm doing 3000rpm at slow acceleration so hoping the new fluid will fix that.
  • Member For: 15y 8m 24d
Posted
Let us know how the service helps the shifting, mines getting a bit sloppy too
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 17y 9m 17d
Posted
I'd be worrying about bottoming out on something and knocking a hose off or putting a hole in the cooler and emptying the trans slowly.
  • Member For: 17y 4m 1d
Posted (edited)
I know from experience if you get a hole in the oil cooler no matter how small, It does not leak slowly.
Edited by ScatterBrain
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 4m 2d
Posted
^^^ 2nd that ^^^
