November 4, 201213 yr #1 v+it wont fit beteen the cooler and the condenser it will be on a angle and I was going to get some tags welded on top of the inter cooler to hold the bottom and make a bracket four the top
November 4, 201213 yr #2 Yes it will work but inlet and outlet need to be either 90 degrees to the way u have it or facing down Done exactly that on my ba and fg
November 4, 201213 yr #3 Author so I need to face the out let;s down facing the intercooler that right. it wont fit with the outlets facing the head light if that makes sence Edited November 4, 201213 yr by RHR Quote removed. USE ADD REPLY
November 4, 201213 yr #4 Anything can work, as long as it gets enough flow through to cool then its fine.
November 4, 201213 yr #6 wait....so the inlet and outlet "should" face down? whys that? mine are faceing up?
November 4, 201213 yr #7 Dude have a think the pump from the trans has to pump fluid up hill then it drops onto the cooler then has to force the oil through the cooler then all the way up again to go down to the trans againSpin the cooler so in and out lets face the headlight or down Yes it will fit theres heaps of room in your pics
