Xr6T Overboost
Featured Replies
#1
Hey guys, this has probably been covered before but anyways I just bought a ba mkII xr6t magnet ute a couple days ago, (WOOHOOO!!!) and while I do love the power it puts down, it looks like its putting out more than it should and thought someone could point me in the right direction. These are its mods :-
k&n filter
fpv cold air intake
siemens injectors (not sure on size)
upgraded wastegate actuator
atomic valve springs
3.5" aps full stainless exhaust
process west front mount intercooler
capa flash tuner
direct clutches semi button clutch
bosch 044
and that gives me a modest 327kw at the wheels =)
Now for my dilema, It was tuned to 15psi but it keeps spiking between 15 and 20 anywhere between half and WOT and it concerns me as im not keen on spitting a rod or melting pistons. I called up the last owner and he told me it started spiking after he replaced the cat converter as the last one collapsed, but that doesnt sound right. can a cat cause boost spikes?
What are my options here? would it be best to take it to a tuner to have a look at its tune or could the wastegate be faulty? I did have an idea to install a boost controller and set to 15 to help control the spike but have read the ecu doesnt like it.
Any input would be greatly appreciated!!!
#2
Changing the cat could definitely cause Boostt issues. Book it in for a retune mate.
#3
:stupid:
#4
It is always advisable to retune with any cat replacement, even if it is the same cat as the old one, as a new one will always be less restrictive than old one. Find out who did the last tune, and take it back to them for a touch up tune. As they will/should have previous tune files saved. It will save you time and money if it is possible. Id bet my left nut (biggest one) the cats your problem. While your at it find out what injectors you have. Will give you an idea if E85 is a future option for you. Cheers
#5
  • Author
oh really? ok then I guess il be booking a retune. The first owner had all the mods done and had it tuned at cv performance in nsw so im not that keen on driving 1000ks away for a touch up tune lol. Is there any reputable capa tuners in bris who can help me out? being too busy I havent really had a good look at the engine bay yet but when I do, is it possible to check injector size on the injector themself? e85 does sound tempting
#6
Ring up CV. They might give you the info you need on the injectors and anything else so you can make life a little easier for the next tuner
Edited by _Velocity_
#7
Go see lee at Real Dyno Performance at Redcliff. he will fix u up mate. 32841925. or for the Gold coast. Hi Torque performance r good to..
#8
  • Author
Velocity. that's a good idea il buzz them 2moro and see wat they say
F6mark. Thanks bro il give them a call pending my one to cv
  • 4 months later...
#9
Mate get a NIZPRO OVERBOOST valve there a great setup . U set it to your boost level u want that's max boost and if it boost spikes the OVERBOOST valve releases the excess boost kinda like a bov. There a awesome bit of kit and good insurance against engine damage. Check the NIZPRO web page out , there on Facebook to man
#10
yeah but not as good an option as a retune, still making the cooler work harder than it has too.
coming from a guy with said valve
Recently Browsing 0
