June 11, 201214 yr #1 Hey guys anyone broken the rear wheel off the turbo because my exhaust end of the wheel snapped off the shaft. Just curious any done this before as I don't no anyone has ever seen this
June 11, 201214 yr #3 2nd this - I have pictures posted somewhere under "How to do it", but bearings seize, and the heavy turbine wheel wants to keep on rotating, and just snaps right off the shaft.
June 19, 201214 yr #5 Bought a standard cat for a BA off a wrecker and when the mechanic went to fit it he banged it a few times and it started to rattle and he turned it up and out fell the rear wheel with bits of the cat. The tuner had never seen anything like it it was wedged into the cat.
June 30, 201214 yr #6 Here are the pics and yes its the wierdest thing ever, I have never seen a rear wheel come off like this. The bearing has not seized but I think the bearings just failed. Anyways decided to upgrade the turbo to a larger GTX35r with the .7AR front cover. I also ported the rear housing, fitted a 38mm swing valve and a garrett 11.8PSI actuator as well. "We" decided go bigger but I had to do all the work and fit it lol. Anyways here are the pics of the broken turbo and the pics of the new turbo I straped to the motor. Was really easy to setup and fit! I may put a kit together and start selling them!!! Edited June 30, 201214 yr by stee3
July 4, 201214 yr #7 Author Guys if you got a fg save your money on all these little mods we all do and just buy a gtx35 they are amazing. I just went threw half a tank of juice and I'm still not over it.
July 4, 201214 yr #8 nice, how do you compare it to the stocker? spool up wise?any other supporting mods? what power?need pics
July 4, 201214 yr #9 Author Okay before I knew a great deal about the turbo on my fg I just went crazy and put all these bolt ons and yeah it went little better but nothing like when I put the turbo on. Mods areXr6turbodevlopments 4" dump and cat60lb injectorsPw stage 2 coolerStainos intake turbo side intakeXr6turbodevlopmemts gtx35 with port job and 12psi actuator Gj strengthened cv"s 6 pot brembosHow's it compare well it's like going from na to turbo. The spool up is just amazing and top end it just keeps pulling
