  • Member For: 20y 11m 15d
Posted (edited)
Hey guys,
I recently had my car run up on the dyno to check the power level and was quite suprised at the result....
The car is an FG XR6T 6spd auto with Rapid Systems intake pipe and XR8 airbox as the only mods, which are both proven to add little to no power.
256rwkw at 9.5psi in 3rd gear on Graham West Dyno in Adelaide. Brett was very shocked at the result and said that most FG's that he gets through make around 220.... He also went as far to say that he thought the car was tuned, as he said that tuned FG's are only putting out between 260 and 270 on his dyno. AFR's were 13 coming on boost, 12 through most of the rev range and dropping to 11.5 at 5700rpm.
The inlet temp was 31 degrees at 2260rpm rising to 50 degrees at 5580, which I assume would be expected with the standard cooler??!
The concerning part for me is the injector duty cycle, as it hits 100% at 4300rpm and continues like that till redline. Is this an issue? It seems like an issue! Brett said it's ok providing I don't get a sh*t batch of fuel or something, and even then, it MAY not cause an issue...
Cheers
Edited by pkaboo
  • G666E Turbo!!!
  • Member For: 16y 8m 22d
Posted
Most make 15-20rwkw more in 3rd than they do in 4th
Other than that is the car 2nd hand? Could have had a tune at some stage
  • G666E Turbo!!!
Posted
Ohh just saw your in adelaide
They put something inthe water over there, it will make 238rwkw in 4th like every other car if dynoed in VIC
  • Like 3
Posted
Purchased as a demo from Ford with 2000km
I get what you're saying about 3rd gear being higher, but I'm comparing directly with other stock Fg's and tuned ones on the same dyno in the same gear....
Posted
The number itself means f*ck all to me, I'm more concerned about the injector duty cycle. I'm still surprised at the number it's making in comparison to others on the same dyno though !!!
  • Member For: 20y 4m 11d
Posted
It's not unusual for FG's to max the injectors with the stock tune
  • Legacy Donating Member
  • Member For: 16y 11m 12d
Posted
I would be concerned about the duty cycle - afr's up top seem like it isn't leaning out so that's a good thing
good enough reason to get a cat, cooler/piping, injectors and a tune :)
