mattxr6tute Member 32 Member For: 13y 7m 23d Gender: Male Location: Australia Queensland Posted 24/10/11 12:41 PM Share Posted 24/10/11 12:41 PM Just wondering.. If I mix the decent nulon octaine booster - claiming to boost fuel octaine by 5 octaine points, with 91 unleaded, will that be safe for use in an xr6T, and would the quality be just as good as 95 octaine? Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/ Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 4m 2d Gender: Male Posted 24/10/11 12:43 PM Share Posted 24/10/11 12:43 PM No and 5 points is not 5 RonMight be passable if you used 95 and it was for limited easy use but I wouldn't if you have a high hp tune Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1153331 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 7d Gender: Male Location: Loitering in SEQ Posted 24/10/11 01:55 PM Share Posted 24/10/11 01:55 PM If its std yeah but I still would'nt, best octane booster ive ever found & used not to mention cheaper is toulene & it will bump ya octane levels up complete points.Are ya using this because you have to or you want to use it? Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1153337 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 22d Gender: Male Location: Far north queensland Posted 24/10/11 10:45 PM Share Posted 24/10/11 10:45 PM Matt - I seem to recall you car is stock. It will run on any petrol out of the pump. Best value I found was running 98 all the time. Once you have run a couple of tanks of 98 disconnect your battery and put your high beams on for 10 mins. Reconnect you battery and keep running 98 from then on. ECU will learn and you will get better economy and more powaah. Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1153377 Share on other sites More sharing options...
brettenator Member 66 Member For: 14y 4m 15d Gender: Male Posted 29/10/11 02:45 PM Share Posted 29/10/11 02:45 PM No and 5 points is not 5 RonWhat is it then?And I'm no chemist, but if the octane booster does what it's supposed to, what's the problem using it? Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1154830 Share on other sites More sharing options...
brettenator Member 66 Member For: 14y 4m 15d Gender: Male Posted 29/10/11 02:51 PM Share Posted 29/10/11 02:51 PM Matt - I seem to recall you car is stock. It will run on any petrol out of the pump. Best value I found was running 98 all the time. Once you have run a couple of tanks of 98 disconnect your battery and put your high beams on for 10 mins. Reconnect you battery and keep running 98 from then on. ECU will learn and you will get better economy and more powaah.Not sure if you're being serious but where'd you learn this? Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1154831 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 22d Gender: Male Location: Far north queensland Posted 29/10/11 08:46 PM Share Posted 29/10/11 08:46 PM Which part Brett? my guess is the part about the battery and ecu1: disconnecting batery and high beams on. This is just a quick and easy way to drain power from your car, high beams drain it pretty quick, only really need a 30 seconds, not harm in 10 mins though just to be sure.2: ecu learning. The ecu will learn how much timing to pull from poor fuel and your driving style and slowly adapt over time to suit. After you reconnect the battery, flog the car if you want power and responsiveness or baby it on the hiway if you want fuel economyThe zf gearboxes also learn your driving style and adapt to suit. Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1154840 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 29d Posted 29/10/11 11:25 PM Share Posted 29/10/11 11:25 PM Octane booster kills iridium plugs. Don't use it! Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1154867 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 6m 9d Gender: Male Location: left right out Posted 31/10/11 07:27 AM Share Posted 31/10/11 07:27 AM Ok for a short while, but will foul plugs over time. My tuner recommends Wynns race formula octane boost which will mimick 98 when added to 95- no pinging, full power etc. He tried all brands available, on the dyno and that's his preference. I use it occasionally, but run 'pure' fuel most times to avoid plug fouling. Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1155342 Share on other sites More sharing options...
brettenator Member 66 Member For: 14y 4m 15d Gender: Male Posted 25/11/11 06:31 AM Share Posted 25/11/11 06:31 AM Which part Brett? my guess is the part about the battery and ecu1: disconnecting batery and high beams on. This is just a quick and easy way to drain power from your car, high beams drain it pretty quick, only really need a 30 seconds, not harm in 10 mins though just to be sure.Hmm ok, dunno why they'd use volatile memory when it's that easy to wipe all your settings but it's pretty possible I guess.2: ecu learning. The ecu will learn how much timing to pull from poor fuel and your driving style and slowly adapt over time to suit. After you reconnect the battery, flog the car if you want power and responsiveness or baby it on the hiway if you want fuel economyThe zf gearboxes also learn your driving style and adapt to suit.Oh I can see how an ECU would make minute corrections based on data gathered previously over time to help with things like knocking and whatever, but noticeably increasing power? How many Watts/Kilowatts are we talking here? :/ Link to comment https://www.fordxr6turbo.com/forum/topic/77503-safe-to-use-91-octaine-fuel-with-octaine-booster/#findComment-1162908 Share on other sites More sharing options...
