  • Member For: 14y 11m 9d
Posted
I am getting all the bolt ons and a tune from xft in Perth
Turbo side 4 inch intake
Nizpro big cooler kit
gtx3582r
waste gate port
16 psi
1000 id injectors
4inch dump
5 inch cat
stock cat back (if I can get away with it. I want it to be a sleeper)
anti surge tank
cooler thermostat etc...
What power output will this get?
What 1/4 time will I get?
This is in a g6et.
  • Replies 21
  • Legacy Donating Member
  • Member For: 19y 1m 13d
Posted
depends on the dyno mate low 300rwk is wat I think I got similar mods and made 280rwk on the nizpro dyno but on any other would make more. Good luck with it at the end of the day its how it performs on the road!!!
  • G666E Turbo!!!
  • Member For: 16y 8m 1d
Posted
Well 1/4 mile time depends on setup track conditions and much more, but I'd expect to be able to run a 10.9 if I had them mods, factor in trans tune too, this is if you run radials LSD prepped track cold night etc... Otherwise you could run into the 12's
Power wise too variable but 350rwkw? Limiting factor is the factory catback, so more boost needed for same power vs 4" exhaust
I'm planing to do similar mods and having run an 11.6 so far even with my current setup I feel if optimized I can go 11.2 with current setup, so better cooler and turbo would have to help there
But its going to be no sleeper with 16psi and a 4" intake LOL no matter how easy you go on the accelerator, it will sound awesome though
Posted
I was expecting that the factory cat back would be restrictive, so am willing to go with a turbo back aftermarket exhaust. I would love to get in the 10s! Will the drivability of the car improve by fitting a LSD? What's it worth to a 1/4 time?
One thing that has got me stunned is, people are telling me to expect low 300-330kw with the mods I am doing. In my eyes, I'm doing everything I can possibly do without strengthening internals. But there are people running 400kw machines without cracking them open. What am I missing?
  • Member For: 16y 1m 21d
Posted (edited)
That's because that's when the stock turbo runs out of puff, maybe they
Missed you were upgrading!
I would prob do valve springs aswell!
Edited by j.d
  • Member For: 19y 3m 23d
Posted
Do the catback..
Silly not to.
Posted
If my tuner (simon at xft) advises that the cat back will make a difference, then I will. So with the gtx3582r installed along with all the other mods mentioned, how much power should I be expecting?
  • Donkey Dick
  • Member For: 16y 5m 30d
Posted
380rwkw, 11.2 @ 128mph if you also put an LSD in it. Single spinner diff will fail hard at the track with decent power
  • Member For: 18y 5m 28d
Posted
Stock catback, with some good valve springs I think you could push as hard as 370rwkw.
Posted
Has anyone made mid to high 300's on a stock catback yet? (FG)
Also didn't Rapid run mid 11's on the single spinner?
