  • Legacy Donating Member
  • Member For: 19y 5m 9d
Posted
agreed.
dont just name and shame, name so other people dont go there and get problems
  • Member For: 17y 9m 30d
Posted
Is it the one that couldn't strap down Icers monster?
  • Here since the start...
  • Member For: 23y 4m 26d
Posted
the second tune after an exhaust change only lasted a week.
Did you change the exhaust without getting a retune?
  • Banned
  • Banned
  • Member For: 16y 9d
Posted (edited)
says 2nd tune AFTER exhaust change. that tells me exhaust done then retune ? no ?
Edited by rab
  • Member For: 19y 2m 27d
Posted (edited)
Not only is the tuner to blame, which was part of the problem to begin with, you should be blaming yourself for knowingly thrashing your car which was to your description, pinging with too much timing.
Edited by xr6t_ute
Posted
Well he did say the second tuner couldn't even finish the dyno run because state of the car but it could also be the fuel.
I know a guy who did the whole rb30 into patrol conversion. was running 15 pound on 91. I told him it wont last. A few weeks later.... rings fried and 2 valves seized.
But there is also the case of people thinking they can tune and people who actually can tune. Unfortunately the guy with the prettiest website isn't necessarily any good.
You can keep going on about it till the cows come home but at the end of the day, if you noticed something isn't right you don't keep booting it hoping it will sort itself out. For some reason I see so many people doing this. Mostly Late model camira drivers.
Posted
Your right there, a few ppl get there cars tuned on 98 and run a lower octane fuel after the tune has been done, heard this story a few times.
  • Member For: 23y 5m 22d
Posted
Driver ignorance is probably the biggest factor in damaging an engine. It does not matter what noise is comming from the engine, they still keep the foot buried.
So the engine was running OK in the first week with 98 octane and then I go and put 89 Octane in and blame the tuner for a bad tune. that's more likely what you call a good tune.
  • Member For: 17y 10d
Posted
Without knowing the whole story from both sides I don't think anyone should be condemning anyone, fuel's vary even between 98 octance fuels, I've seen cars ping on Shell vortec that don't knock in the slightest on BP and Mobil, I always try to educate my customers and it's also another reason why good tunes are below the knock threshold and the knock sensors are left on so the ECU can hopefully pull timing out when fuel quality is poor, but at the end of the day, to have a perfomance car means having some mechanical sympathy and knowing when things are not quite right.
Joel
  • Member For: 17y 8m 30d
Posted
Exhaust change, back to the first tuner and re-tuned. All sweet. Not driven until a week later had foot into it & helmet on heard it pinging then missing, damage done. (was willing to wear this, my fault must have been a mechanical failure no ones to blame ra ra ra should have heard it earlier). Engine re-built ran on dyno with SAME fuel in tank when engine let go, was TOLD current tune had several flaws that would have contributed to the detonation. Info of the flaws was sent to old mate, cant explain it. Now im outa pocket wads of cash no way of getting it back. I can deal with that. Maybe that it was a combination of a lot of things, quite possibly it was the tune or bad fuel. Only ever had 98 in it but how do you know your getting 98 from a bowser, is it not a busy servo, 98 bowser hardly used, has the fuel gone off, down to 95 etc etc... Was it on boarder line?
