June 14, 201115 yr #1 Hey guys, just wondering which u would chose first? I can't do both at once, so which should I do first?Its a bf f6, manual.Its going to be either a full exhaust, with injectors, fuel pump plus tune orintercooler kit with pipes and under battery cold air, plus injectors, fuel pump and tune..which one first and why?
June 14, 201115 yr #2 save yaself some money, hi-flow cat, injectors, fuel pump plus tune. you'll have some left over to put towards a cooler later on.
June 15, 201115 yr #3 Would you really need the fuel pump? As mentioned a cat is worth a look. How bout cooler, pipes, intake, injectors, high flow cat then tune..
June 15, 201115 yr #4 How about delaying the mods a little longer until you have the cash for the cooler too?You'll save yourself money on tuning if you do it all in one go.
June 15, 201115 yr #5 go cooler and intake I think u might get less power than exhaust but then u get induction noise
June 15, 201115 yr #7 Would you really need the fuel pump? As mentioned a cat is worth a look. How bout cooler, pipes, intake, injectors, high flow cat then tune..Bam! Cheapest proven path for good power. I'm thinkin of even seeing how the stock cooler goes first as I don't think many have pushed the fg one for sh*t's and giggles, if it's useless I'll just throw a pwr one in.
June 15, 201115 yr #8 With that youll be looking at 300, definitely go the fuel pump. There only around $150
