Ekul Member 15 Member For: 15y 5m 1d Gender: Male Location: Hawkes Bay - New Zealand Posted 28/04/11 11:46 PM Posted 28/04/11 11:46 PM Just been having a look at the Iridium NGK plugs that are mentioned in this thread - Repco want $32.99 each for them, but anybody can get them off Amazon for just US$6.95 each - what is all that about...?They seem to be listed under 2 NGK numbers - not sure if they are different plugs, NGK BKR6EIX and NGK BKR6EIX-11 - maybe somebody can enlighten us?Does this plug really make that much difference at the cylinder pressures generated by vehicles running just regular 98RON or less? Would just the standard plug correctly gapped and in good condition be just as good?
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Legacy Donating Member 1,808 Member For: 17y 9m 4d Gender: Male Posted 29/04/11 03:07 AM Posted 29/04/11 03:07 AM BKR6EIX-11 = 1.1 mm gap, whereas the BKR6EIX = .8mm gap.I only changed mine to the .8mm because I didn't realise the BF has .9mm gap from factory whereas the BA has 1.1.
FPV6T UNDERCOAT CRUISER!!! Legacy Donating Member 1,655 Member For: 17y 8m 3d Gender: Male Location: brisbane Posted 29/04/11 03:10 AM Posted 29/04/11 03:10 AM EKUL,I got my NGK plugs from the USA cost me $55 delivered for a set of 6.You need to get NGK BKR6EIX p/n (6418)pregapped at .8 The other ones are gapped at 1.1 .if you running more than stock boost you need to gap plugs at .8
Brods Member 433 Member For: 16y 1m 23d Gender: Male Posted 29/04/11 07:27 AM Posted 29/04/11 07:27 AM Why so KABOOOOOM...? No problem for a strong late model engine.Peak at 17psi hold 13psi under hard acceleration - by the time peak boost hits and you fell the really strong acceleartion the vehicle is already going over 140km/hr. Its not like you are going to drive like that too often. The boost starts to falls off before limiter revs. Not exactly boosting at 17psi all day and everyday - just got to mind how you go and be sensible with it. Make sure to only use 98RON if driving hard - maybe add 5 litres of toluene... -Anything generic should be thrown in the bin. I hope you at least have had it on the dyno to check your AFR's. I do believe the fg's have weaker internals than the BF mk11. I'd hate to see you blow a hole in your block.
Lof818 Member 54 Member For: 16y 1m 14d Gender: Male Location: Bribie island Posted 29/04/11 07:26 PM Author Posted 29/04/11 07:26 PM I had been running staned platnum plugs in there they lasted 15,000kms geeeee lol what a waste of mopney they should of lasted around 90,000kms ppl tell me any way I changed to the .8m gap and geeee my car goes and goes and goes some people say it doesnt make a difference but I saw the difference as far as the oil goes I can try 10w-40 ful syn in my car and it will run better I hope
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 10m 24d Gender: Male Location: Perth Posted 30/04/11 12:27 AM Posted 30/04/11 12:27 AM (edited) just grab BF ford plugs and regap from 0.9 to 0.8 and I use the oil which castrol and nulon recommend as their No 1 choice for XR6 turbo and F6 which is 0/40 Edited 30/04/11 12:29 AM by arronm
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 26d Gender: Male Location: Victoria Posted 30/04/11 12:38 AM Posted 30/04/11 12:38 AM Why would you do that when you can just buy the pre-gapped plugs?
alpha Member 266 Member For: 19y 6m 17d Gender: Male Location: Perth Posted 30/04/11 12:40 AM Posted 30/04/11 12:40 AM Fully synthetic Nulon on my Tornado. I was using Mobil (fargin expensive), but was recommended Nulon by members on this forum. Alot cheaper cheaper then other brands.
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 26d Gender: Male Location: Victoria Posted 30/04/11 12:42 AM Posted 30/04/11 12:42 AM Agreed.I buy it in 20L drums and it's MUCH cheaper than a lot of the other brands.
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 10m 24d Gender: Male Location: Perth Posted 30/04/11 12:43 AM Posted 30/04/11 12:43 AM Why would you do that when you can just buy the pre-gapped plugs?Cause the plugs are $7 each and good enough for my 500HP
