23/02/11 04:25 AM23/02/11 04:25 AM #21 Not at all, was just saying it looks like the capa one, I assume that's where they got the idea from.
23/02/11 10:24 PM23/02/11 10:24 PM #22 Author Installed pictures of the Cooler, and the original dyno sheet.
27/02/11 10:20 PM27/02/11 10:20 PM #23 Author Bit of an update:Tune and 60lb injectors were done on Friday. She's a rocket!Race tune is 365rwkw at 18psiStreet tune is ~350rwkw at 16psiLower power tune is 340rwkw and 10psiGreat service and great outcome. Now time to look into handling mods!I'll chuck dyno sheets up at some stage...
28/02/11 04:38 AM28/02/11 04:38 AM #24 What happened to your goal of 320? That power level seems a bit dangerous if it's the early bottom end.
28/02/11 04:56 AM28/02/11 04:56 AM #25 And can someone explain why theres only 10rwkw difference between 6psi ?? Haha, that seems a little odd :sRegardless, nice figure. Has the turbo had any work done to it ?
28/02/11 05:12 AM28/02/11 05:12 AM #26 hub dyno always reads a bit more dont forget henz.but that minimal power difference with 6psi...well..donno.well done on the massive power. time to take it to the track. Should see 123+mph with that power. With a pre 06/06 I hope it lasts you at least a while! Enjoy it
28/02/11 05:25 AM28/02/11 05:25 AM #27 Need to see printouts of the two lower power runs. Maybe it's a peak figure thing with the lowest power tune not having hardly any mid range?
28/02/11 05:27 AM28/02/11 05:27 AM #28 Ahh I always forget which shop has the hub dyno. So probably 340ish? which is borderline safe. If I had thatmotor Ild go there.
28/02/11 06:00 AM28/02/11 06:00 AM #29 Perhaps its peak power but regardless I don't see a difference of 10kw with 6psi regardless where abouts it is in the midrange. Perhaps with a td04 but the 35r wouldn be making leaps and bounds with each pound. Need to see the graphs.
28/02/11 06:27 AM28/02/11 06:27 AM #30 Im with Steve, could have a lot to do with how much timing as well. Thread needs some Ratter or Headsex. And the dyno sheets.
