A300srt8 Member 507 Member For: 21y 8m 21d Posted 29/10/10 06:00 AM Posted 29/10/10 06:00 AM any one got the run down on fitting a Plazmaman PlenumThanks
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 8d Gender: Male Location: OZ Posted 29/10/10 06:20 AM Posted 29/10/10 06:20 AM Yes...you need to source a lot of minor parts too fit it all in one hit. This is one plenum that isn't supplied in a kit form. Also rather than drilling out the lower plenum holes on the passenger side go buy yourself some studs to thread into the lower manifold and bolt it down from the top. It won't look as pretty but its much much easier and will provide a better clamp. If it's a power coated plenum ditch the metal gasket and just use a good quality goo instead. They're a very good plenum though so enjoy :-)
hawlass Legacy Donating Member 1,161 Member For: 18y 10m 7d Gender: Male Location: left right out Posted 29/10/10 06:27 AM Posted 29/10/10 06:27 AM I'm doing the same soon too, what are these 'minor parts' you mentioned- wiring harness and gasket goo obviously, but what else?
A300srt8 Member 507 Member For: 21y 8m 21d Posted 29/10/10 06:41 AM Author Posted 29/10/10 06:41 AM I have to whole kit with a ETm turbo etc
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 8d Gender: Male Location: OZ Posted 29/10/10 08:06 AM Posted 29/10/10 08:06 AM extend brake booster line, extend fuel pressure reg line, extend throttle wiring harness, drink beer....forget the rest! I think the PCV line fits as is IIRC.
possum Legacy Donating Member 553 Member For: 17y 3m 24d Gender: Male Posted 29/10/10 08:08 AM Posted 29/10/10 08:08 AM Be wary, I fitted mine ages ago, no thread tapped into the throttle body holes, the bolt holdin in the mapSensor is a different size, the inner bolts are *beep* to get to....... Not really a fun job on a weekend but well worth it at the end of the day
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 8d Gender: Male Location: OZ Posted 29/10/10 08:30 AM Posted 29/10/10 08:30 AM Ahhh yes the MAP sensor.....so true, good pick-up possum!!!Use a hex key with the ball style ends for the inner ones, works a treat :-)
plazmaman Member 43 Member For: 20y 18d Posted 30/10/10 04:36 AM Posted 30/10/10 04:36 AM All plenums come with vaccum fittings and studs/nuts as standard . as of a few months ago all plenums now come COMPLETE with brake booster extension hose , vaccum line and there is an option when purchasing to buy a plug in loom ($75). We offer this as an option as many of you guys prefer to solder the wiring (we supply free of charge) as it keeps the total cost of the unit down . ih8toads , our powdercoating process has changed , so you can use the gasket now as well . As for the beer , I highly recommend it when working on cars . possum , sorry bout the tbody flange holes , we had a tap break in the CNC and only noticed the day after we sent yours .
hawlass Legacy Donating Member 1,161 Member For: 18y 10m 7d Gender: Male Location: left right out Posted 30/10/10 05:01 AM Posted 30/10/10 05:01 AM So does anyone have the install manual?
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 8d Gender: Male Location: OZ Posted 30/10/10 10:22 AM Posted 30/10/10 10:22 AM Sweet, good work plazmaman! I was stoked with the results from my plenum. Damn good investment!
