nxr06 Legacy Donating Member 117 Member For: 22y 5m 2d Posted 23/08/10 10:45 AM Posted 23/08/10 10:45 AM Can some1 post pics of how they did there flapper mods on here
HI PSI Member 1,589 Member For: 20y 4m 4d Gender: Male Location: Central Queensland Posted 23/08/10 11:31 AM Posted 23/08/10 11:31 AM This is how I did mine... Porting the housing....I hope that this helps.....
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 4d Gender: Male Location: Melbourne Posted 23/08/10 11:34 AM Posted 23/08/10 11:34 AM nice pics HI PSIbut nxr06 its prob easier to take it to a workshop who knows what there doing, but if you want to give it a crack yourself go for it. hopefully someone can give you some tips.
HI PSI Member 1,589 Member For: 20y 4m 4d Gender: Male Location: Central Queensland Posted 23/08/10 12:02 PM Posted 23/08/10 12:02 PM This is how I did mine... Porting the housing....I ported mine myself. It is relativey easy. It works fne and holds a perfectly stable bost. I would not advise doing it yourself if it is your every day driver. Being my first time. It took me around 3 hrs to port the housing as I was a touch overcautious and took a great deal of time theorising the flow characteristics of the flapper.. I was both lucky and appreciative that a forum member (Ratter (thanks again bud) gave me a few tips... I was also luck enough to purchase a spare housing and do this at my leasure.. I fitted the housing, apid V3 kit, Injectors, exhaust all at the same time... On and off, it took me 1 1/2 days... The port itsef has to be ovaled as the floor and roof of the housing are the limtations... I was told to port the houing as if it was a valve job in cylinder head... I was very careful when taking out th closest wall as I feel that if left too tin, it could be prone to hotspots and therefore promote cracking. You must also be carefule not to remove too much material from the stud area.. The back lip must have substantial material removed to createa rounded edge. I assumed that a hard square edge would create turulence around the flapper which could possibly cause the flapper to inadvertantly open slightly..I had my seating surface milled to remove the raised factory seaing. This provided us with a larger, flatter seating area for the enlarged flapper. Interference material around the flapper shaft was alo removed at this time as the flapper would no sit central on the port and was cathing on the flapper...A local machining shop performed these tasks for $80.... All of this is a breeze... Wait till you pull the turbo off and put it back on again..... That is another story all in itself....I hope that this helps....
bazz Legacy Donating Member 76 Member For: 18y 8m 21d Gender: Male Location: slacks creek QLD Posted 04/09/10 11:13 AM Posted 04/09/10 11:13 AM This is how I did mine... I was also luck enough to purchase a spare housing and do this at my leasure.. where did you buy your spare housing from?I want to pre-plan all my mods and have all parts ready to bolt on, so my car is not off the road for days
Panda Eyes flame magnet Legacy Donating Member 5,674 Member For: 18y 4m 13d Gender: Male Location: adelaide hills- 'race air' central Posted 04/09/10 07:08 PM Posted 04/09/10 07:08 PM whats it worth to have a workshop do it?
HI PSI Member 1,589 Member For: 20y 4m 4d Gender: Male Location: Central Queensland Posted 04/09/10 10:01 PM Posted 04/09/10 10:01 PM where did you buy your spare housing from?I purchased mine from the sale section of Ford Forums....
JVK Legacy Donating Member 751 Member For: 20y 9m 11d Gender: Male Location: North West Hot Hell,VIC Posted 05/09/10 01:11 AM Posted 05/09/10 01:11 AM Nice photos and post HI PSI, will certainly help other members.
