  • Member For: 18y 2m 12d
Posted
Is the traction control adjustable via a tune or by any other means? I have a BA 4 speed. I like traction control but would like it to allow a bit more wheel spin.
  • Member For: 17y 8m 18d
Posted
Don't think so mate, you will find after a tune it will go into fail mode cos it can't handle the extra power. If it goes into fail mode, it will be disabled until you turn the engine off and start it again. Real PITA in the wet.
  • Legacy Donating Member
  • Member For: 18y 9m 3d
Posted
Mine still works properly after tune (if I leave it on), though I generally turn it off as soon as I get in the car every time now.
Posted
Yeah, mine works properly as well, but if I'm really giving it a hard time the traction control just give up and turns off. I believe the TC with a ZF allows a bit more twitch then the 4spd.
Posted
It feels so bad for the car when it hits that I just dont let it happen when its on anymore.
Posted
Sheesh, mines only on TC for a split second before it turns itself off and don't even notice it most of the time, but it's been tuned for torque so wheel spin is easy.
Posted
This is exactly what I want
http://www.racelogic.co.uk/?show=Traction_Control-Products_and_Pricing-Digital_Adjuster
"Slip levels are adjustable in 1% increments from 0% up to 25%, and launch control comes as standard. Cut level thresholds, rev limits, wheel sizes and RPM operating levels can all be altered in real-time."
Chiptorque is a distributor but it is listed at 595 british pounds. so mybe a bit
much
  • Member For: 17y 11m 22d
Posted
you mean the light turns off ? if not how can you get it to turn its self off ?
  • Member For: 20y 3m 20d
Posted
IS there a fuse or something you can take out to disable the TC?
  • Member For: 18y 5m 11d
Posted
Yea I think mine just gives up and turns off lol
I have only had it 1 day before fuel pump shat it self so havn't really tested it much
