bigblu222 New Member 13 Member For: 17y 7m 12d Gender: Male Location: Kapiti Posted 28/01/10 06:26 AM Posted 28/01/10 06:26 AM I've just bought an FPV intercooler.What are the ramifications if I install it in my XR6T?Do I need a retune or custom tune? Or will the ECU pick up the difference in airflow (if any) and compensate automatically.Cheers
tab Sucker Moderating Team 32,303 Member For: 22y 5m 6d Gender: Male Location: Brisbane Posted 28/01/10 07:14 AM Posted 28/01/10 07:14 AM Just plug it in and you should be right as the difference between the two is not that great. You would need a retune to make use of the extra available killerwasps....but I don't think it'd be worth doing for just that alone.
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Legacy Donating Member 1,808 Member For: 17y 9m 15d Gender: Male Posted 28/01/10 07:48 AM Posted 28/01/10 07:48 AM can't see how a bigger 'cooler gives you extra killawasps, rather it stops the decline in killawasps after continued hard runs.
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 3d Gender: Male Location: central coast Posted 28/01/10 10:29 PM Posted 28/01/10 10:29 PM not the bigger part it's the better flow / less restriction that gives more power and the big size does as you said
blueprinted_xr Member 4 Member For: 18y 2m Posted 16/02/10 05:22 AM Posted 16/02/10 05:22 AM any issues with fiting a BA FPV intercooler into a BF mk11 Xr6 turbo?
RHR BOOST Moderating Team 5,698 Member For: 23y 26d Gender: Male Location: Southern Highlands NSW Posted 16/02/10 11:12 AM Posted 16/02/10 11:12 AM Ba and BF phoons have the same cooler.. So no issues
gwk Member 28 Member For: 18y 3m 9d Gender: Male Location: Gold coast Posted 06/03/10 01:29 PM Posted 06/03/10 01:29 PM (edited) Hi 'revheadrobbo,BA and BF Phoons probably do have the same coolers BUT a stock BA/BF XR6T cooler is 50% smaller than a PHOON cooler. The only reason I fitted a BA Phoon cooler to my stock BF XR6T today was for that reason(50% larger) and the price was not too shabby either.Blueprinted xr A bit of thought before starting out won't go astray for anyone doing this upgrade. I found a tread on this site relating to removal of the front bar/bumper in order to respray the intercooler..............very helpfull.Note: you will need to drill 2 holes.(relocate the passenger side mounting bracket,you need the Phoon bracket) you will need to plug the Phoon's "boost gauge sender unit" threaded hole(driver's side). Cheers Edited 06/03/10 01:31 PM by gwk
BFHOON Legacy Donating Member 1,932 Member For: 20y 6m 7d Gender: Male Location: nsw Posted 06/03/10 02:17 PM Posted 06/03/10 02:17 PM you can use the stock xr6 mounting brackets just flip the passenger side bracket up side down and drill one hole.
gwk Member 28 Member For: 18y 3m 9d Gender: Male Location: Gold coast Posted 07/03/10 12:55 AM Posted 07/03/10 12:55 AM 'BFHOON'I knew I should have looked outside the "square"Cheers
Process West Member 248 Member For: 20y 3m 29d Gender: Male Location: Wollongong NSW Posted 07/03/10 04:27 AM Posted 07/03/10 04:27 AM can't see how a bigger 'cooler gives you extra killawasps, rather it stops the decline in killawasps after continued hard runs.A more effecient intercooler will give lower outlet temps (and in turn more power) right from the get go.The factory intercooler is a horrible thing and has bad outlet temps even when stone cold on a stock set up.Kev
