  • 570Nm @1800rpm
  • Legacy Donating Member
  • Member For: 23y 12d
Posted
Looking through the Nolathane catalog I noticed they have a 1" lowering block kit for BA/BF utes and wagons.
I was under the impression that you could not use lowering blocks does to shock absorber clearance etc. Surely they would not make the kit if it could not be used?
Anyone used one of these?
Cheers.
  • Member For: 23y 8m 16d
Posted
personally I would prefer these over the Herrod lowered leaf, mine used to tramp something terrible. Where as the stock spring would hardly ever tramp...
  • Forged Member
  • Member For: 19y 7m 26d
Posted
You can get away with 1" Lowering blocks, but that's it - if you have 20's you may ba able to squeeze a 1.5" in there.
  • 570Nm @1800rpm
Posted
senna_T, have you seen or fitted these kits before? Are they any good?
A 1" drop in the back is more then enough.
Cheers.
  • Member For: 21y 8m 17d
Posted
I used them in my ba ute when I had it and worked a treat
they are technicaly illegal but I didnt care
brett
  • Member For: 17y 1m 15d
Posted
I thought it was legal as long as the lowest point of the vehicle is above 100 mm?? maybe wrong but would be a better option than using the aluminium ones
Posted
all lowering blocks r illegal due to the added strain they put on the springs
that the rule in nsw may be diffrent in other states
but as long as u keep a sensable hieght no one tends to pick on them
  • Member For: 16y 10m 16d
Posted (edited)
my brother used them on his persuit ute, it has 20"s though, ive been for a ride in it and it is not as smooth as it youst to be e.g feel alot more bumps than it youst to but damn it sits low now, tuff as here is after and before. the before is a bit sh*t but look at the differance from the back guard to the rim
Edited by seeman
  • 570Nm @1800rpm
Posted
seeman, are you sure he used 1" blocks? That looks like more then a 1" drop to me.
From my understanding all that these blocks do is move the diff up buy adding the block spacer between the spring and the diff. I do not see how this would put extra strain on the springs.
I'll give them a try and if the are :spoton: I'll pull em back out :shocked:
Posted
im not too sure how much it dropped but he got them from pedders and they were like 80 or 100 dollars, and they were called lowering blocks so im pritty sure that is it yer.
