  • Member For: 18y 4m 13d
Posted
Hey Guys,
It's prob already been covered, but I am ready to change fuel filter and was wondering where it is on the BF T? And when I remove it will fuel go everywhere?
Marty
  • Legacy Donating Member
  • Member For: 19y 11m 28d
Posted
Located in the middle of the passenge side doors..
  • Member For: 18y 10m 1d
Posted
We changed mine out with 1/4 tank and very little fuel spilt out of the pipes. Cheers to dad for having the special vice grip pliers though, the nut would NOT budge. Tight as a nuns...
Watch out you don't round the nuts!
  • Banned
  • Member For: 17y 3m 14d
Posted
Run the car and pull the fuel pump fuse out. This will dry up the line and release the pressure from the lines.
Posted
If I just undo it there should only be a little bit of fuel in it right?
What vice pliers are we talking about so I can purchase some.
Marty
  • Member For: 23y 21d
Posted (edited)
Not much fuel comes out, just use a rag underneath.
Vice Grips, those adjustable um grip things used for gripping.
Better try using the correct spanners first but if that fails then resort the vice grips, which I had to do as the last monkey who replaced mine threaded the nut on the output side! Nip up the new one and just test by priming the pump a few times to get pressure, check for a leak and just keep nipping it tighter until it doesn't leak.
Edited by bjc
Posted
seeing I work at Bunnings, there are many a vice grip. Just incase I'll pick one up what does it look like?
Posted
The ones I have got have the same head on them as multi grips.
Pretty much as long as you can clamp it down real tight then it should do.
Posted (edited)
I actually used a different style, I don't know the correct name, it's shaped like a toothed beak sorta, the more you pull the more it tightens up, like a chinese finger trap. The correct size spanners still started rounding the nuts, they were stupidly tight.
A better tip might be WD-40 on the nuts, let it sit a couple mins and try again. The self tightening grips actually got stuck ON and were a bitch to remove. Good thing I let the old man do it hahaha!
Edited by -SteveR-
