  • Member For: 17y 5m 18d
Posted
the twin plate was fuct within a week of getting it tuned up
taking the car to them today hope they will sort it out
  • Replies 20
  • Moar Powar Babeh
  • Legacy Donating Member
  • Member For: 21y 13d
Posted
do you still have the stock clutch?
Have you changed the CSC to an alloy one? Please dont take offencde but your running pretty low power to go through so many clutches. I'd be looking at other causes such as a plastic CSC thats partially jammed and applying pressure to the clutch release springs
Oh and sell me your AP clutch if you still have it :beerchug:
Posted
yea I still got the AP clutch how much u offering? it been sittin for a while and is a lil rusty
wat do you meen by CSC? is that the slave cylinder/throwout bearing thing?
well I was just on my way to get it looked at and it didnt slip (typical) anyway so I called the guy at the clutch place and he says it happens some times they slip a couple time to bed in properly so he said just give it a bit of a floggin to make sure it wont slip so I did and guess wat, the oil light came on and I got a rattle in the engine cars sittin on the side of the road. just one thing after anouther
getting it towed soon.
  • Member For: 19y 5m 20d
Posted
Mate that's not good, hope the rattle isn't anything serious.
Your AP twin plate should have supported that sort of power unless your tune is REALLY aggressive. It could be the CSC not releasing the clutch completely.
I would hang on to that standard clutch and speak to another work shop. The AP should heaps better than Exedy cushion button.
Posted
as I asked in my previous post wats a csc?
when I got the tune they said the standard clutch wouldnt last and it didnt, same thing with most other ppl I know with T's that have mod's done
  • Member For: 17y 8m 5d
Posted
Like everyone has said mate there must be something NQR.
  • loitering with intent
  • Member For: 23y 1m 17d
Posted
concentric slave cylinder
  • Just a large member member
  • Member For: 17y 11m 20d
Posted
so what is happening to the old clutches...are you wearing away only one surface...breaking them or is the pressure plate throwing it in.....
When I use to fit clutch kits to old fords sometimes the travel from the clutch master cylinder wasn't right so we had to adjust the pushrod in the back of the cluch master cylinder for correct travel.Yours might be to long ...meaning the clutch will be slightly engauged all the time thus slipping all the time...
Posted (edited)
thanks buf phoon, that's wat I thought it ment
no the other clutches went because the spline was rough and grabbing the plate, well that's wat I was told, I seen the first and the plate was melted mech said hes never seen anything like it.
but wat you are sayin sounds very probable fits the symptoms
Edited by baf6
Posted
mate as you have been told in your lost oil pressure post...go find yourself someone who know something about these cars...It seems to me the only thing right that your mechanic has done for you is take your money....
As for your comment on the post above....the spline was rough and grabbing the plate...
Well it would have to be the spline on the input shaft of the gearbox as the cluch was new...If what he said was true the input shaft would have to be bent...If so why would you fit it...then go out and do some wheel work to bed it in.....This bloke makes me look good and not many people do....Get you car the fark out of there go to a reasonable mechanic...pay the money and get it fixed....This bloke who's working on your car now is he a mate or dose he not charge as much as the others.....
