August 29, 200917 yr #1 Firstly what stock lb injectors are in the 05,06,07,08 BF Phoon?....and what is their max rwkw before changing to a higher lb?What are these numbers for XR6T?Was looking at a CAPAs website and they suggest this for 300-330 flywheel KW?or do they refer to rwkw??Sorry if repost...havent found the search button on this new format yet
August 29, 200917 yr #2 I'm pretty sure on the capa website they talk in flywheel kW. sound more impressive at first look.but I cant really answer your first question
August 29, 200917 yr #3 In BA and BF's, Xr6t's and F6 they all run out at about 250ish rwkw Strange for some one who as been on for quite some time, you should know that already.
August 29, 200917 yr #4 Author Yeh couldnt be farked looking back through mate...its here somewhere I'll bet Tab will find it shortly...The wog got mine to 275rw with a Capa box, wog cooler, 2CAI, K&N and cust tune....he didnt even mention changing the injects
August 30, 200917 yr #6 I'll bet Tab will find it shortly...What....that you've posted in the Wanted To Buy section? Farkin newbs
August 30, 200917 yr #8 May be wrong but believe all BA / BF F6 and T stock injectors are 28lb... mine are at their limit hence upgrading to 968's, pump and cat for my retune... I'd say your 275rwkw would be limited due to injectors also.
