  • Legacy Donating Member
  • Member For: 22y 8m 7d
Posted
the next door neighbour just bought an fg ute... has 3000km on it now... he describes a sound of a light rattle that seems to be coming from under the cabin... although when he takes off he describes the sound as coming from the back??
now when my flex plate went it sounded very similar and I actually thought the sound was coming from the rear... that is until it got really bad and I tought the engine went.
also the thought of a baffle has come up.
ford have no ideas and just send him on his way saying its fixed....... and each time the sound still turns up.
anyone have any ideas as to where such a rattle could be coming from? any oher fg drivers have a rattel issue?
cheers
  • Forged Member
  • Member For: 19y 8m 1d
Posted
Is it a manual or auto jetters?
  • Member For: 20y 1m 13d
Posted
exhaust all aligned properly? Not fouling anywhere?
Purge valve?
Whats his serial number?
  • Massive Tool
  • Member For: 18y 26d
Posted
Jet
I have a pretty bed rattle/noise happen at idle however it only happens when the car is in drive. The dealer said they know where the problem is and will fix it next time I take it in.(Next couple of weeks) I recall talking breifly to fg270 last cruise and he had the same problem to.
Timmy
Posted
sennat... its an auto
bunna.. no idea on serial number
timmy.... did they say what it is?
  • Forged Member
Posted
Hmmm, interesting - maybe some heat-shielding...
  • Member For: 18y 9d
Posted
has been around since the dawn of time...
idle is too low... interior is too sh*t....
I work at ford get cars in all the time... theres no way of adjusting idle without a flash tune....
reflash is what I get told to do on them all the time by the manager but it does sh*t all....
  • It's not a MKI!
  • Member For: 18y 3m 19d
Posted
Mine's pretty much got the smae rattle you describe, jetute.
I found it to be inside the exhaust pipe somewhere. Possibly the centre muffler.
It goes away when you raise the revs slightly and appears to get worse when the revs drop as the aircon compressor cuts in.
It's been there for the last 10000+kms and isn't really a worry as you can't here it in the car only when your outside next to it.
I'm not going to worry about it as I plan on replacing the standard exhaust in the future with my power upgrades.
  • Massive Tool
Posted
They said it wasnt heat sheilds.
And mine is different to phantmxr6 as you can only hear it in the car not outside it.
They said if someone holds the exhaust it stops and the reason they didnt pick it up after I told them was because you cant hear it outside the car.
Which when I tried it myself is true. but inside its a friggen nightmare.
Timmy
Posted
thanks all... ill pass this thread onto him.... could possibly help him with his issue.
