  • Member For: 20y 28d
Any chance someone could put the pics back up again? Mine just broke and I ordered the replacement gear from mikesmodelcars, thanks for the link too.
I'll put the new one in and repair the old one per above instructions so I have a spare then.
  • 2 weeks later...
  • Member For: 15y 3m 29d
Tried fixing mine using this method, the screw I put in made the cog a bit thicker and it couldn't fit through the plastic thread thing. Does anyone know where to buy the cogs directly for cheap, as a local 2nd hand parts store is selling them for $60! Surely they're not even worth $30. I might check out some "hobby" shops to see if they recognize the part.
  • 6 months later...
  • 1 month later...
  • 4 months later...
  • Inactive Members
  • Member For: 13y 10m 25d
just replaced door lock actuator cog drivers side front, I am having trouble getting door back on as plastic clip keeps coming out of the lock end of locking rod anyone got any tips on doing this or do I need to pack something behind clip to stop it popping out
  • 5 weeks later...
  • Member For: 16y 1m 29d
Undo all the screws and starting from the bottom pull door trim off.
Unclip the electric windows cable. On the right side of the door push the plastic clip through. This will give you some slack on the cable.
Remove the lock using a T30 bit.
Swing the black clip holding the bar clockwise and remove the bar.
With the lock now out undo wire harness.
Undo the 2 screws to remove the actuator from the lock.
Undo the 4 screws securing the 2 halves together. Carefully pull the 2 pieces apart. There are 2 springs inside that can fly out.
Remove the broken gear and glue the gear back together. (Selley’s Quick Fix)
Using a 2.5mm drill bit drill down the centre of the gear.
Using the appropriate tap, tap the hole ready for a 2.8mm screw.
Put a drop of glue down the hole and screw the 2 pieces together.
Install in reverse order
Good Luck
Big thanks to XR06T for donating the broken gear. :eyebrows:
got me a new cog from a guy for $19 on ebay who bought 10 and only ended up needing 1.
followed your directions except I unplugged the electric windows before removing door screws and undid the lock harness before unscrewing the lock.
cheers brother :drinks:
Edited by mwoonkey
  • 2 years later...
  • Here since the start...
  • Member For: 22y 1m 4d
Just pull it apart mate. They're a simple bit of kit. You won't have any trouble figuring it out.
  • Member For: 18y 8m 1d
Pics aren't working. I was gonna make a thread with pics when I did mine but realized there was already one. Ill see if I have the pics still, pretty easy though
Only pics I have for some reason, dunno what happened to the rest
Trim removal
Door lock (actuator on the right, comes out in 1 piece like this)
Inside the actuator housing (remember how the springs and washers go back onto the worm gear)
How it stops working
Edited by freeze_dk
