crazyhorse Member 14 Member For: 16y 5m 8d Gender: Female Location: Brisbane Posted 16/05/09 04:09 AM Share Posted 16/05/09 04:09 AM Hi guysI bought my FG XR6 turbo in August, and have had it in for its 15000km service. It began clunking changing up and down gears and during excelleration, a mate got under it and reckons its the coupling that joins the tail shaft onto the diff. So I took it back to Ford, and they are replacing the entire tail shaft.Ford reckon its from having too heavy a weight in the tray, though I don't think a few bales of hay and some bags of horse feed would equal a heavy weight. The ford service guy reckons he has seen a few of them, (with one car coming in with that coupling totally distroyed) and the heavy weight excuse is coming from the Ford Factory... just thought I would give you a heads up that there seems to be a bit of an issue in this area of the car.I am also getting my suspension tightened as the car bottoms out on bumps on the highway, a little hard to steer clear of when your doing 100+ kms an hour.Has anyone else had any issues like this or am I the only lucky one? Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/ Share on other sites More sharing options...
TUFGSR Member 514 Member For: 20y 4m 10d Posted 16/05/09 06:09 AM Share Posted 16/05/09 06:09 AM It seems to be a common problem now mate, I broke the centre bearing in my tail shaft with a full tub load while giving it a bit of stick. Some guys are breaking them on stockers, some modified so it definately is a design fault. A sorce tells me the cvs where never designed to handle even the stock power. Wether this is true or not I am not sure. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877097 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 1d Gender: Male Location: Sydney NSW Posted 16/05/09 08:56 AM Share Posted 16/05/09 08:56 AM Is this just utes, or sedans too?My old BA ate 2 front tail shaft couplers, and one centre bearing/bush, so I dont want to go through that again. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877146 Share on other sites More sharing options...
jasol Member 571 Member For: 16y 4m 24d Location: adelaide Posted 16/05/09 11:55 AM Share Posted 16/05/09 11:55 AM my centre bearing was making noise as I stoped, ford replaced the whole tailshaft, they said this was very uncommon mines a bf though Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877194 Share on other sites More sharing options...
tinyplums Member 1,080 Member For: 16y 10m 17d Gender: Male Posted 16/05/09 06:55 PM Share Posted 16/05/09 06:55 PM mines going in monday for new shaft, stock power just lowered 65mm Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877245 Share on other sites More sharing options...
xtremerus Member 59 Member For: 16y 1m 29d Location: North-West NSW Posted 17/05/09 08:45 AM Share Posted 17/05/09 08:45 AM The Falcon utes have a single tailshaft and no center bearing, I thought. I could be wrong. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877499 Share on other sites More sharing options...
TUFGSR Member 514 Member For: 20y 4m 10d Posted 17/05/09 12:25 PM Share Posted 17/05/09 12:25 PM The FG utes run a two peice tailshaft with two cvs and there both sh*t. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877673 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 6m 18d Gender: Male Location: SoR, WA Posted 17/05/09 12:34 PM Share Posted 17/05/09 12:34 PM Best thing for the FG's is to fit a BF tailshaft.Ford truly stuffed up the FG shaft. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877681 Share on other sites More sharing options...
jasol Member 571 Member For: 16y 4m 24d Location: adelaide Posted 17/05/09 01:15 PM Share Posted 17/05/09 01:15 PM The Falcon utes have a single tailshaft and no center bearing, I thought. I could be wrong.all xr's have a 2 piece normal falcon utes have a single Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-877701 Share on other sites More sharing options...
crazyhorse Member 14 Member For: 16y 5m 8d Gender: Female Location: Brisbane Posted 18/05/09 12:52 PM Author Share Posted 18/05/09 12:52 PM bugger sorry to hear about your troubles guys, I wondered if it was me giving it a bit too much gas every now and then, but it sounds like a design fault. Sure hope I don't have to get the tail shaft replaced every 15,000kms or I will be trading it in for a moped. Link to comment https://www.fordxr6turbo.com/forum/topic/57691-tail-shaft-problems-fg-xr6-t/#findComment-878087 Share on other sites More sharing options...
