  • Member For: 17y 9m 10d
Posted
'06 XR6T with dual zone climate control has started a very annoying ticking when the climate control is on. Not always but most of the time. Experimenting seems to suggest it is the fan motor.
Anyone had trouble like this & is it a big job to repair/replace?
I'm still under warranty for a couple of months.
Guest newl
  • Guests
Posted
Mine does this too. Comes and goes. Hrmm..come to think of it, I haven't heard it in quite a while. Originally thought it was a leaf or something like that. Suppose I should check out the filter one of these days. :nono:
Let us know what you find out.
  • Member For: 19y 6m 20d
Posted
mine does the same thing and I thought I had a leaf stuck too but it would have broken up and moved on by now.
  • Legacy Donating Member
  • Member For: 18y 6m 25d
Posted
Mine does it as well. I'll take a look at it over the weekend.
  • Member For: 18y 2m 24d
Posted
My fan in my BF MK11 XR6 Turbo does it too!!!... not so much a "ticking noise" more a slight high pitch squeeking noise" that changes tone according to the fan speed... above 30% max fan speed it disapears... GGGRRR!!!
Guest newl
  • Guests
Posted
Cleaned my filter out last week. It really needed it too :w00t2:. Was piss easy to do. Drop the glove box, reach in, pull filter tray to the left (you'll see where it says open left, close right), clean it out, reverse to install. Problem solvered. :diggit:
  • Member For: 18y 9m 12d
Posted
If it's a leaf, hammer the speed of the fan to see if it can be dislodged. Also open and close vents with it on full noise.
fordfreak, this sort of thing has driven VZ Late model camira owners crazy.........may be dry bushes in the fan motor?
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 8d
Posted
Are they doing that under warranty?
