  • Member For: 18y 1m 11d
Posted
apart from the 10mm clearance from lowest point to the ground, is there anything else illegal about lowering a BA? I want to keep mine legal but still lower it, what can u do with the bumpstops to keep it legal
oh and does anyone know if sl's(f) and ssl's or sl's®is legal?
thanks all
  • Replies 21
  • My engine bay is Bionic
  • Legacy Donating Member
  • Member For: 20y 6m 10d
Posted
I think its 100mm and the rest I have no idea.
I.B.
  • A much better forum
  • Member For: 18y 2m 6d
Posted
Depends on your state champ... Think you can look it up on the web...
Posted
Every State is always very differnet in this area, but could you really lower your car to 10mm. I think he meant to write 100mm, not 10mm was my point.
Pleased your on top of it all. :blink:
I.B.
  • CNUTOX
  • Member For: 23y 8m 23d
Posted
Get new bumpstops or cut the first knob off the factory ones.
  • Member For: 19y 6m 18d
Posted
Yeah I wouldn't go cutting ANYTHING on your car if you want to keep it legal.
  • Member For: 18y 5d
Posted (edited)
I checked vic roads for this a while back.
http://www.vicroads.vic.gov.au/Home/RulesS...rdsInformation/
In a PDF doc it states:
4. Ground Clearance
"The ground clearance of a vehicle measured from a horitontal road surface to any point on the underside of the vehicle except the tyres, wheels and wheel hubs and brake backing plates shall, with the vehicle located in it's loaded state as specified by the manufacturer be not less than:
* for any point in the width of the vehicle which is within one metre fore and aft of any axle, 100mm
* for the mid-point between any two consecutive axels, the dimension in millimetres obtained by multiplying the distance in metres between those two axels by 33.33"
5.Lowering or Raising of Vehicles
" A vehicle may be lowered or raised, provided the clearance between a suspension component and it's assosiated bump stop is not altered by more than 1/3 of that specified by the manufacturer. in addition, the original relationship between the front and rear suspension heights must not be unduly affected.
Suspension coil springs must not be shortened by cutting. If lowering blocks are used, they must be manufactured from either steel, aluminium or a metal of equivalent hardness."
I saved that pdf a while back as it is a good reference guide when thinking about mods. Plus if you get pulled over is good to know and understand the difference between legal and illegal.
brad
Edited by Sleeper6T
Posted
Sounds like an Australian design regulation and on that basis it's likely to be the same in all States.
I.B.
Posted
that cleared it up, so pretty much dont alter bumpstops to much or lower less than 100mm, do they measure it with only 1 passenger in the car or wat, because its stated "in its loaded state"
