dule Legacy Donating Member 1,180 Member For: 19y 5m 22d Gender: Male Location: Sydney Posted 14/10/08 09:43 AM Posted 14/10/08 09:43 AM Diff should only affect fuel consumption on open road, as for example at a 100 you car will not sit at 1800rpm but 2500 instead.
Doogstar Member 276 Member For: 19y 9m 11d Posted 14/10/08 09:45 AM Posted 14/10/08 09:45 AM Yeah, that's about right. If you get a new LSD get a 4 pinion LSD, much tougher than the stock 2 pinion.Look for Differential Workshops, also a lot of Auto shops do it as well. Otherwise try performance shops. Yellow pages is your friend.
104ord Member 391 Member For: 18y 6m 21d Gender: Male Location: north brisbane Posted 14/10/08 09:50 AM Posted 14/10/08 09:50 AM I was thinking that just a minispool will do me for now but ill look into this option aswell and ill post y findings for you
Doogstar Member 276 Member For: 19y 9m 11d Posted 14/10/08 09:53 AM Posted 14/10/08 09:53 AM Diff should only affect fuel consumption on open road, as for example at a 100 you car will not sit at 1800rpm but 2500 instead.NAh, was about 2,300rpm
coolkid Member 94 Member For: 18y 24d Posted 14/10/08 09:59 AM Author Posted 14/10/08 09:59 AM obviously those are the findings for 4.11 am I right??
Doogstar Member 276 Member For: 19y 9m 11d Posted 14/10/08 10:02 AM Posted 14/10/08 10:02 AM Yeah, I used to have a chart that tells you what rpm you do at what speed with the different ratios. Trying to find it.
Doogstar Member 276 Member For: 19y 9m 11d Posted 14/10/08 10:09 AM Posted 14/10/08 10:09 AM (edited) 4th gear revs in relation to road speed with different ratio diffs on 17" rims.3.45@110 kpm = 2128 rpm3.45@100 kpm = 1935 rpm3.45@80 kpm = 1548 rpm3.9@110 kpm = 2406 rpm3.9@100 kpm = 2187 rpm3.9@80 kpm = 1750 rpm4.11@110 kpm = 2535 rpm4.11@100 kpm = 2305 rpm4.11@80 kpm = 1844 rpm Edited 14/10/08 10:22 AM by Doogstar
coolkid Member 94 Member For: 18y 24d Posted 14/10/08 10:46 AM Author Posted 14/10/08 10:46 AM hmmm. anyone know what the standard diff ratio is in a falcon? totally cant remember...
Doogstar Member 276 Member For: 19y 9m 11d Posted 14/10/08 10:51 AM Posted 14/10/08 10:51 AM BA XR6 4spd = 3.45 BA XT 4 spd= 3.23
Azzman460 Azzman Member 223 Member For: 18y 2m 16d Gender: Male Location: Melbourne Posted 16/10/08 12:23 AM Posted 16/10/08 12:23 AM So getting a higher diff ratio, say the 4.11's will give you much better accelleration but a lower top speed?
