  • Every Mod's Favourite Member
  • Member For: 18y 7m 1d
Posted
The last 2 times I've given the TT some stick off the line (in sports auto) it's let loose with an huge CLUNK! just prior to hitting second gear. It sounds like a diff clunk, but I'm not sure. Any ideas?
  • Replies 24
  • Forged Member
  • Legacy Donating Member
  • Member For: 19y 7m 29d
Posted
Does it happen any other time or in manual mode mate? Possibly diff bush, auto could need some TLC too. If you can (in a safe and quiet area), try and put it in manual mode in 1st and hop on and off the gas to get the car lurching back and forth, this may show up the problem too if something is loose
  • Member For: 18y 11m 12d
Posted
I had similar noises in similar situations and it ended up being the auto- sh*t itself. This would be the worst case scenario, dont want to scare you!!! :dontknow:
  • Member For: 19y 4m 9d
Posted
At a guess it is the center rear bush, visable if you take a wheel off or look behind the spare wheel cradle. Its the big mutha dead centre and wears out in many instances every 15,000Klms. The alternate FF site has a big write up on this one but would appear to be consistent with the prob you have.
Good luck
Posted
It only occurs when in the sports auto.
When shifting manually, or flooring it in normal auto, it holds perfectly and is dead smooth. Flick it over to sports auto and do the same and CLUNK! right between the gear change. This kind of makes me lean toward an auto issue, but I'm not sure why that'd throw down a clunk in the rear (and only the rear).
Is there anyone I can take the car to for a quick check up to diagnose, or is it harder than that.
  • Forged Member
Posted
Maybe HP-F? Does it do it when you run the stock tune (if you still can)?
Posted (edited)
Now THAT's a good idea. I'll flash it back tonight and see what happens. Cheers Senna. :unsure:
Edited by Grudgee
  • Moderating Team
  • Member For: 23y 8m 5d
Posted
Wouldnt happen if you drove a proper car........
  • Forged Member
Posted
lol, did you sort it out Phillipe?
