  • Here since the start...
  • Member For: 22y 2m 19d
Any time under 12.50 requires a time slip to be added.
We'll remove anytime under 12.50 without a timeslip in 7 days. That should give people enough time to update their entry.
  • Sucker
  • Moderating Team
  • Member For: 21y 2m 20d
Bit of both :B):
CJ increased the limit, and I reduced his dyno sheet to fit - the original timeslip (in post #1) was OK.
If you don't have any luck then just PM them to me or post them up here if you like?
  • Member For: 18y 4m 2d
ok I got my timeslip in, im not even going to bother with the dyno printout.
the nature of timeslips is that they are long and skinny , the allowable file size does not like long images= problem for most
  • The Noble Leader
  • Administrator
  • Member For: 22y 9m 3d
What do you think the timeslip size should be? I will adjust it accordingly.
Cheers
dunno im not much of a computer guru lol but the allowable file size doesn't allow enough height, I had to resise and then crop mine till all that was left was the actual data from the run, none of the details of the track or date etc
