  • Legacy Donating Member
  • Member For: 20y 6m 4d
Posted (edited)
ok I said CFM
SCFM = Standard cubic feet per minute air flow @ 20.3” H20 backpressure
The SCFM rating of respective mufflers of the same and quality brand are rated as this as we know the mufflers are more restrictive than pipes in the exhaust. Specs quoted from quality dynomax ultraflow mufflers.
3.5 inch 2200+cfm
2.5 inch 1000cfm x 2
Although the difference being small would negate to not much of a difference but the sh*tness of the Y section in the common twin systems as you said would be more of a limiting factor. Exhaust cross section is only one area to look at.
Edited by Fatsex
  • Replies 45
  • Member For: 21y 6m 1d
Posted (edited)
I have an X-force twin 2.5 system, and the sh*tness level of the Y pipe was at the overflowing level of crap measurement.
The pipes look good on the outside, but where the air is flowing was rubbish.
Saying that, we welded the joins up and ground it all up nicely, and it should be heaps better.
Would be interesting to measure the flow pre de-sh*tting the pipe and after
Edited by cobrav8
  • Member For: 20y 5m 6d
Posted (edited)
Spoke to Dave on the phone today regarding my top end power curve in comparison to Grizzlys'.
Dave has investigated stating the difference is'nt due to my Nizpro flowed Exhaust Turbo housing or twin 2.5" X-Force system. Apparently my stronger top end is all to do with the tune! :pooh::spoton: :spoton:
Edited by 2MUCHKW
  • Member For: 19y 18d
Posted
posted in the FPV section too but I'm just so proud!!! 380RWKW!!!!
BF R-spec Typhoon 6 speed auto: Process West race plenum kit
Process West surge tank
X-Force 3.5" system with 4" dump
60lb semins injectors
12psi actuator and ported wastgate
Flash Tuner 2
And a big thanks to Dave from CPV Tuning for all his advice and time spent on the tuning. Couldn't be happier with the results............well maybe if I can net a low 11 or even a 10.9 at the strip.!!!
I have just about all the same mods but I have the old p/w kit with the new intake and my power is about the same at 18 psi down to 17 its good to see with just about the same mods and different tuners we made the same power
  • Member For: 22y 7m 24d
Posted
Dave has investigated stating the difference is'nt due to my Nizpro flowed Exhaust Turbo housing or twin 2.5" X-Force system. Apparently my stronger top end is all to do with the tune! :nutkick::spoton: :spoton:
is yours a manual or auto?
did dave tune yours as well? sounds like it anyway?
nice power that you guys have!! enjoy it!
Posted (edited)
geezuz.... might have to drive up there for a tune
how does your auto change? is there anything done in that department?
Edited by jetute
Posted
Auto changes perfectly bloke... hes tuned allot of ZF's now
Dave gives very personalised service and can tune the car to suit your driving style.
Dont ask Dave what my driving style is! :kissmy::ielh:
  • Member For: 21y 4m 13d
Posted
Well done Nathan. When are you heading out to the strip to try her out?
  • Member For: 21y 1m 14d
Posted
He has already been Bryce. First meeting for Palmyra in 6 months since the track was repaired from the floods. I'll let him state his times if he wishes (or you could just check cm), but when he goes back in 3 weeks time they should be much quicker (between the tnt last Friday night and the race meet Saturday night people has cut 0.5s off their times as the track got some rubber down).
Oh yeah it's Jason here too :)
