  • Member For: 22y 4m 1d
Posted (edited)
3rd is best while low power and torque, but to hard to hook up once the power is this high imo.
the dyno does not realy show the full difference between intercoolers, because you are only taking about 10 sec, to do a run.
if we held it for 30 sec at full power, you would see the benifit of a big intercooler.
that is the highest I have seen on our dyno, with no mod to the turbo (flow wise),on 98octane, but the turbo is out at this power, so the gains are small, when you put larger intake and intercooler on. The real gains are out on the road, where the intake temps are kept lower.
David
Edited by Dagabond
  • Replies 45
  • Member For: 20y 5m 9d
Posted (edited)
Dave I've downloaded this dyno sheet and overlayed mine ... can clearly see now that the Nizpro exhaust turbine housing definitely sacifices a little low end but gives much more top end punch.
Even though my car produces peak power of 378.2rwkw at 174kph which is almost identical things are much different at 200-210kph where I have over 30-35rwkw more then this setup.
Do you have a 15KPH/secUp dyno run of this car?
I dont have a 98ron 20KPH/secUP dyno run to compare with :outahere:
Edited by 2MUCHKW
Posted
yeh I have, when I go down the dyno, I might over lay yours and his if you want.
but there is another reason that your car pulled away after peak power I think, and I will try
this before I coment.
David
Posted
Cool ... be good to see a 15KPH/secUp dyno run chart of this car.
What do you think altered the power curves?
Do you think the 3.5" single X-force was restrictive @ the top end compared to the twin 2.5" X-Force system on my car?
I noted fuel was Shell 98ron ... is there any noticable difference over BP ultimate Dave?
  • Into the laaaake
  • Member For: 19y 3m 14d
Posted
Wow, great work David. As Groper mentioned earlier, good to see yet another happy CPV customer.
Posted
I will pm you on that, because the difference that yours made is a mod in that tune I think, the base one I used, (you know what I mean) and I don't know if they would like me to tell everyone about it.
no I don't think it is the exhaust or fuel, the cat is the most restrictive part, I think with both gutted, the 3.5 will flow the best.imo
David
  • CNUTOX
  • Legacy Donating Member
  • Member For: 23y 8m 22d
Posted
Love your work Dave. Well done grizzle guts!!
Awesome having realkws isn't it!
I can see why my mate asks question of you Dave, you know your Tuna from Salmon!
  • Member For: 20y 6m 7d
Posted
David
:laughing:
Just by looking at the CFM flow rates of a single 3.5 inch pipe vs a 2.5 inch pipe x 2 the 3.5 inch outflows it easy.
  • Member For: 19y 7m 27d
Posted
no it doesnt...
cross sectional area of 2x 2.5in pipes = 39.25sq inches
cross sectional area or 1x 3.5in pipe = 38.46sq inches
in practice, the single system may flow 'ever so slightly' better due to less surface friction and no y piece.
in reality, its hardly gonna matter in the slightest... and the dyno numbers all over this forum with either system prove they are making around the same power regardless...
