June 16, 200818 yr #1 Hey guys,I know you's are probably getting sick of answering these things but bear with me please.I have a BA MK1 xr6t. I am putting a T56 from malwood into my car as to handle more power.My question is I want to get into the 400rwkw club and am wondering what is needed to acheive this.so far I have - 42lb injectors, cold air intake, capa flash tuner.on the way I have X-Force 3.5" exhaust, valve springs, fuel pump.Will I need to upgrade any of the internals on the xr6 to handle this sort of power?I am really serious to do this and need some help as I dont know much about these cars. so any help would be good..thanksbrody Edited June 18, 200818 yr by Dagabond
June 17, 200818 yr #2 yes heavy duty rods ,pistons bearings and oil pump gears just to start with if you where to go 350rwkw you could just buy an f6 bottom end for under $3000 to go 400 is goin to get expensive
June 17, 200818 yr #4 Author so getting a F6 bottom end is going to be the go eh? Why is it that they are stronger?senna_T - will 60lb injectors be enough for this?
June 17, 200818 yr #5 The 60lb injextors will get you there. If you try to do it with the bottom end from a ba1 it will end in tears as you will trow a rod. The bf F6 bottom end is the cheep way of getting the job done. You will have to look at an intercooler as well and maybe some pipework changes. I feel that the oilpump would also be a worth wile upgrade aswell as they do tend to fail at high rpm.GK
June 18, 200818 yr #6 Author is it very hard to sorce an F6 bottom end? or am I just better of getting the forgies and rod myself and putting them in?
June 18, 200818 yr #9 Engines aside, this is one way to get 400Bigger injectors- 60lbFuel pump - 044 (surge tanks is a good idea to use, maybe a fuel reg)Intercooler (not a direct swap cooler, something big and high flowing)PlenumPiping to suit IC-plenumIntake- 3 or 4inch (not under battery type intake)4inch exhaust- turbo backTuned on 18-20psiTurbo wastegate enlarged (or external gate)Stonger accuator (or external gate)Then a very good clutch, twin or tripple plate to hold the power.
July 31, 200818 yr #10 Author Are you looking to bolt something together yourself, or via a workshop?Most likely via a workshop...Engines aside, this is one way to get 400Bigger injectors- 60lbFuel pump - 044 (surge tanks is a good idea to use, maybe a fuel reg)Intercooler (not a direct swap cooler, something big and high flowing)PlenumPiping to suit IC-plenumIntake- 3 or 4inch (not under battery type intake)4inch exhaust- turbo backTuned on 18-20psiTurbo wastegate enlarged (or external gate)Stonger accuator (or external gate)Then a very good clutch, twin or tripple plate to hold the power.Thanks mate
