will-82 Member 427 Member For: 21y 8m 13d Location: sydney Posted 23/05/08 07:54 AM Author Posted 23/05/08 07:54 AM checked the rest of the bolts couple we a fraction loose, but the noise didnt go away :(its sounds like a snake in the engine bay on boostdrove through a tunnel tonight and the tunnel echos the noise even morewiill be puting it on a hoist tomorrow and checking all the hoses underneathand the hose to the throttle body, does anyone know what size it is iff I want to replace it with silicone?will let u all know when I fix ittalk soon brett
bjc Legacy Donating Member 2,823 Member For: 23y 25d Gender: Male Location: Townsville Posted 23/05/08 11:42 AM Posted 23/05/08 11:42 AM You sure the previous owner didn't have boost gauges, removed them and left the vacuum line in behind the dash and didn't block them off properly?
yw84u Member 148 Member For: 20y 8m 17d Gender: Male Location: Gold Coast Posted 23/05/08 10:46 PM Posted 23/05/08 10:46 PM (edited) Check your grommets there might be a hole in one of them if the previous owner ran anything through the firewall. I get a very slight whistle in the cabin through one my grommets where my wires for my gauges come through the firewall. that just reminds me I really have to sikaflex it up. Edited 23/05/08 10:49 PM by yw84u
will-82 Member 427 Member For: 21y 8m 13d Location: sydney Posted 24/05/08 03:23 AM Author Posted 24/05/08 03:23 AM ive checked the fire wall and the lines around the inlet manifold and cant find an evidence of anything out of placeive check the pipe into the throttle body its fineI found the clamp for the pressure side of the compressore housing not on properly. fixed that and its still thereim going to find this thing if it the last thing I dowill keep u informedbrett
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 20y 4m 25d Gender: Male Posted 24/05/08 03:25 AM Posted 24/05/08 03:25 AM Did you check the dump pipe bolts under the heat sheild?, also check that the gasket between the turbo housing and the mainfold isnt blown/cracked?
will-82 Member 427 Member For: 21y 8m 13d Location: sydney Posted 24/05/08 03:43 AM Author Posted 24/05/08 03:43 AM while I was in there I checked all the dump pipe bolts, thought it would save on taking it apart again
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 20y 4m 25d Gender: Male Posted 24/05/08 04:13 AM Posted 24/05/08 04:13 AM ahh ok well I wouldnt have clue whats going on then bud.Good luck and lets us know what it was
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 24/05/08 04:17 AM Posted 24/05/08 04:17 AM check the rubber hose that connects the crossover to the throttle body, this has been known to get small cracks in it, especially on the underside - good luck!
will-82 Member 427 Member For: 21y 8m 13d Location: sydney Posted 24/05/08 04:56 AM Author Posted 24/05/08 04:56 AM (edited) found it, becuase its a manual there is a grommet on the fire wall where the clutch line go throughand beacuase its ripped and so close to the turbo charger the noise its actually the exhuast gasses mixing in the dump pipemicrophones r helpful thingshas anyone noticed that the factory blow off valve looks like its backwards?] Edited 24/05/08 04:57 AM by will-82
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 24/05/08 05:00 AM Posted 24/05/08 05:00 AM well there you go! yeah the stock BOV looks wrong, just change it out for a decent one that will hold shut under higher boost.
