  • Mmmmm......BOOST
  • Member For: 19y 4m 24d
Posted
what would the minimum temp you would run an auto box at ,with my cooler set up mine runs around 110f when just cruising 140f with a few fast hills etc,and it has gone up to 160f with about 10minutes of constant punishment ,I don't have a thermo switch on the trans cooler fan ,just wondering if it's to cold when cruising
  • Replies 20
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 20y 4m 17d
Posted
I run 335 through a dead stock box no trans cooler either, ive only been running this power for awhile but ive been running 300rwkw with this box for over a year.
I also run 11.8 on this box with about 25 pass down the strip,all with stalling.
So yeah every box is different but I think mines a freak :spit:
  • Member For: 22y 3m 25d
Posted
not sure how cool oil goes in a trany, I normaly run it through the radiator on the way back, so it keeps it at about 180 f.
David
  • Legacy Donating Member
  • Member For: 19y 5m 18d
Posted
my 4spd last 6 months of constant punishment with 313rwkw
before giving up 3rd and 4th gear
  • Member For: 23y 5m 22d
Posted
They are a very strong box if you make them shift harder, and there are a couple of tricks in doing this. You can do it via the S5 solenoid which is OK for mild power levels but there is another step where you eliminate the S5 function altogether and gives maximum shifting hardness. And it doesnt snap input shafts like the ZF does.
  • Member For: 19y 1m 3d
Posted
So yeah every box is different but I think mines a freak :pinch:
You might have a freak but our tuner churns out very linear power curves which are very kind on the drive train.
Posted
I dont know about linear, mines a pretty full on tune :spoton:
Posted
Show us ya dyno graph!
  • Member For: 21y 4m 14d
Posted (edited)
my btr 4 speed has been modded by tony dominello and is supporting
460 rwkw with 2800 stall for 3000 ks and no problems so far.
cheers geoff
Edited by rapidute
