  • Legacy Donating Member
  • Member For: 20y 5m 1d
Posted (edited)
HEY GUYS
JUST CURIOUS IF ANYONE KNOWS THE SPECS ON THE FPV F6 TYPHOON DIFF RATIO AND IF THERE DIFFERENT TO AUTO AND MANUAL TRANSMISSIONS
ALSO IF THEY ARE DIFFERENT FROM A XR6 TURBO ?
AND IF YOU GUYS KNOW ANYONE THAT HAS ONE FOR SALE THAT WOULD BE GREAT
I CRACKED MY DIFF DON'T KNOW THE FULL EXTENT OF THE DAMAGE UNTIL I PULL IT OUT
ANY ADVICE ON WHAT TO DO
THANKS
Edited by BLUUOA
  • Hench, but no longer shredded or tanned.
  • Member For: 19y 6m 10d
Posted
2.73 on the 6 speed auto I'm pretty sure
  • Toughest BA Turbo
  • Member For: 23y 9m 14d
Posted
2.73 on 6-speed auto
3.46 on 4-speed auto & 5-speed manual
3.73 on 6-speed manual
As I told you last Wednesday night putting slicks on the car will put a lot more strain on driveline, especially running big power.
I thought you'd have a cv or auto problem before the diff.
That's why most of us with the ZF's are using MT's, plus less hassle running at the track.
Good luck sorting it out.
Brian
Posted
Hey Brian
Could you give me some advice is there any difference between a standard diff and a FPV diff ?
What is the cheapest way out of this
  • Toughest BA Turbo
Posted
Should be the same Dana diff.
You might be able to get diff from a wrecker.
You have to drop the cradle to get the diff replaced. That's around $400 in labour.
Whilst your doing that I'd advise that you inspect the cv's.
Brian
  • Member For: 19y 3m 15d
Posted
Heve you found out the extent of the damage yet?
Im suprised youve broken the actual Dif internals, would have thought the CV would go first.
Didnt happen to just break the rear Diff cover? I have one of them for sale at the moment.
(this is usually the first thing to go)
Posted
Not yet pulling out the diff today with the help of a few friends
Thanks I'll see the extent of the damage and get back to you
Is the Standard XR6 Turbo Diff The Same ? If so are they the same ratios
Should I go 3.75 ?
Posted
Should I go 3.75 ?
yep m86 Dana diff in both
Posted
If you're after something a bit stronger that will hold up to the punishment of 400+rwkw at the strip I'd recomend a KAAZ 2 way. I have one in my car after smashing a few standard centres and can't fault it's performance/durability (it is very noisy though :w00t2: ). They're pretty pricey at ~$2800 fitted but well worth it :spoton:
Posted
Yeah spoke to someone today about the KAAZ LSD but got one really cheap today so I'll just make use of this one for now it's got 3.46 which is a much better ratio of 2.73 which is in mine at the moment
have to recalibrate my dash for the change in wheel speed and I'll be right
When I get some time I'll rebuild my old one with strengthen gearing with the KAAZ LSD with either chrome molly drive shafts or billet ones if there at the right price
Anyway the extent of the damage is
I snapped my hemisphere in half which broke the rod which went out the back of the casing
