DRTYBOOST Member 363 Member For: 19y 6m 29d Gender: Male Location: Perth, WA Posted 07/03/08 05:29 PM Posted 07/03/08 05:29 PM Im stuck for ideas and I need some help on what my next move can be to get more powerI dont want to start building my engine so that's out off the question.atm ive got-Fuel PumpWog Cooler (prototype) NO PIPINGInjectorsZorstgot the capa software aswellgot all the basic stuff eg bov,cai, snorkleand I got the mal op 3 to handel it allits pushing 326 rwkw atmWhat other mods can I do to get me more power but not start building the engine?
steetf6 Banned 163 Member For: 18y 8m 11d Gender: Male Location: wa Posted 07/03/08 05:41 PM Posted 07/03/08 05:41 PM what exhaust you got?
Guest Wingnut Guests Posted 07/03/08 10:31 PM Posted 07/03/08 10:31 PM You need to build your engine. Im sure there are things you could do to make it run the same power using less fuel boost timing whatever else.... The most obvious thing to look at first I would think would be getting some sort of FMIC and Plenum set up going. I.e. Nizpro stage 2, Plazmaman 800-1000hp kit, Process west....Im sure that would make things a little easier for you to produce some power but unless you have a BF MK11 (I think that's the one with better bottom end) then anymore power you will be pushing the limits.I am in the same boat as you... Have around the same power and obviously want more but when ever I talk to a workshop or tuner they advise me to sort the bottom end as it could become quite costly if I happen to break something..
smarty Member 37 Member For: 19y 3m 12d Gender: Male Location: Adelaide Posted 09/03/08 10:38 AM Posted 09/03/08 10:38 AM You need to build your engine. Im sure there are things you could do to make it run the same power using less fuel boost timing whatever else.... The most obvious thing to look at first I would think would be getting some sort of FMIC and Plenum set up going. I.e. Nizpro stage 2, Plazmaman 800-1000hp kit, Process west....Im sure that would make things a little easier for you to produce some power but unless you have a BF MK11 (I think that's the one with better bottom end) then anymore power you will be pushing the limits.I am in the same boat as you... Have around the same power and obviously want more but when ever I talk to a workshop or tuner they advise me to sort the bottom end as it could become quite costly if I happen to break something..what model ba-bf 1 or 2?are they 60 lb squirters?that zorst got dump and cat?
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 19y 6m 8d Gender: Male Location: Canning Vale, W.A Posted 09/03/08 10:41 AM Posted 09/03/08 10:41 AM (edited) Actuator/wastegate,plenum,surge tankhigh 300s with high boost and good fuel but you're risking your internals.Mind you groper is going alright so far!^ that's what im left to do then im happy, because I dont want to do internals either haha Edited 09/03/08 10:42 AM by Silhoutte6T
DRTYBOOST Member 363 Member For: 19y 6m 29d Gender: Male Location: Perth, WA Posted 10/03/08 03:34 AM Author Posted 10/03/08 03:34 AM Actuator/wastegate,plenum,surge tankhigh 300s with high boost and good fuel but you're risking your internals.Mind you groper is going alright so far!^ that's what im left to do then im happy, because I dont want to do internals either hahahaha yeh we are on the same page.smarty its a 06 bf mkII with 72lb injectors, nah just got full turbo back 3 inch z force.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 28d Gender: Male Location: SW Sydney Posted 10/03/08 04:24 AM Posted 10/03/08 04:24 AM mate unless you want to go for a new cooler, at least get a bigger under battery pipe - they make a big difference.But that cooler is holding you back - look at something that gets rid of the crossover and you'll make the same power at less boost, and more at the same boost!as silhouette6T said, the actuator will help you hold boost, and a surge tank will be good safety
smarty Member 37 Member For: 19y 3m 12d Gender: Male Location: Adelaide Posted 10/03/08 10:48 AM Posted 10/03/08 10:48 AM good call pat
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 28d Gender: Male Location: SW Sydney Posted 10/03/08 11:11 AM Posted 10/03/08 11:11 AM
rhysy_boi Member 83 Member For: 20y 2m 21d Gender: Male Location: Perth, WA Posted 11/03/08 09:40 AM Posted 11/03/08 09:40 AM 3 inch is WAY undersized. I have a 3 inch on mine running 260rwkw and it's one of my restictive points. should be going a 4inch at least or twin 2.5-3's if your going huge power.Rhys
