  • Mad Scientist
  • Member For: 21y 10m 12d
Posted
Cos Dane helped you!!!
:+1: I'll remember that when u come up in january and its 45 degrees and u want to swim in my pool :idunno:
but I'll still bring honeywheats and penguins when I come down after xmas :w00t2:
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 16d
Posted
But apparently its almost as loud as ENVY-T :stupid:
That's impossible :nono:
  • Member For: 19y 6m 28d
Posted
you must have removed a 1 way check valve somewhere during the install.
the fuel pressure is now seeping back through the fuel pump while it sits and that always results in a hard to start engine.
get yourself a speedflow 1 way check valve and fit it to the fuel line after the high pressure pump and it will start perfectly again.
  • Member For: 19y 10d
Posted
You are onto something here... I just tried a couple of things when starting the ute.
First I let the pump prime fully and when the pump stopped priming I started the ute and had the starting problems.
Then I tried starting the ute half-way through the priming process and perfect start. I done this a few times and it started perfect every time.
So I am loosing pressure somewhere. Where are these 1 way check valves?
