DRTYBOOST Member 363 Member For: 18y 3m 2d Gender: Male Location: Perth, WA Posted 12/11/07 02:36 AM Share Posted 12/11/07 02:36 AM hijust a question, I was thinking of getting extrernal gate!the mainfold is internal so obviously you would have weld it up to external?has anyone done it? whats involved and how much would it cost? Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 1d Gender: Male Location: SW Sydney Posted 12/11/07 03:10 AM Share Posted 12/11/07 03:10 AM you will basically need a new manifold, I can see bcl is watching, he will have some good comments for you I would assume, you'll also need a new dump pipe and (duh) the rear housing will probably need to be changed for proper efficiency Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594859 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 14d Gender: Male Location: Sydney Posted 12/11/07 03:18 AM Share Posted 12/11/07 03:18 AM I'll assume you refer to an external wastegate.The wastegate is internal, not the manifold.I don't know of anyone that has welded shut the internal wastegate on the Ford, so that they can run an external wategate. I have done that on my STi, so I know what you mean.Unless you are running in excess of say 420-450rwkw you would be better staying with an internal wastegate, but use a larger flapper valve.I'd only run an external wastegate in conjuction with extractors and dual inlet entry turbo.There are many mods you do before this one.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594860 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 1d Gender: Male Location: SW Sydney Posted 12/11/07 03:35 AM Share Posted 12/11/07 03:35 AM words of experience there DRTYBOOST, unless you go BIG, not much need, its an expensive option! Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594865 Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 5m Location: North Brisbane Posted 12/11/07 04:36 AM Share Posted 12/11/07 04:36 AM As Brian said, there are plenty more mods before you get to this! Like strengthening your engine for reliability for one............. Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594886 Share on other sites More sharing options...
DRTYBOOST Member 363 Member For: 18y 3m 2d Gender: Male Location: Perth, WA Posted 12/11/07 06:12 AM Author Share Posted 12/11/07 06:12 AM cheers will keep this in mind, im only running 288rwkw atm should be about 320rwkw by end off this month so ill look into it when I hit the 400 mark LOL!! Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594935 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 11m 18d Gender: Male Posted 12/11/07 07:26 AM Share Posted 12/11/07 07:26 AM a long way to go yet Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594961 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 19d Gender: Male Location: Sydney NSW Posted 12/11/07 07:59 AM Share Posted 12/11/07 07:59 AM I plan to do this at some stage soon, it's another option other than the usual hogging out of the internal gate, that for, isnt a hard thing to do, but I'm not a fan of internal gates so I wont go any futher with the internal, but that's just me.Opening up the internal gate and fitting a larger flapper is the common way to increase boost controland works fine.If you were to go for an external, you'll have to mod the manifold, its not a hard job for someone with the know how, but its no bolt on job.First you'll need to remove the manifold, drill a big ( 40-50mm ) hole in it somewhere, usually in the colector area. Weld on a pipe with the external gates flange welded on the other end, mount the wastegate, make another pipe that comes OFF the wastegate and goes down to the dump pipe and joins into it.Alot of work in deciding where to mount the w'gate and fabricating the piping to join it all up.If your lost by all this forget about it, but if your keen go for it as a good external wastegate, say a 50mm TIAL, would be alot better than the internal gate.As a side note, an advantage of this would be the ability to run low boost on a very high flowing intake/IC/ exhaust system... internal gates are too small to allow low boost on these high flowing systems. Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594976 Share on other sites More sharing options...
Muzza No V6 for me thanks!! Donating Members 583 Member For: 19y 10m 2d Location: Newcastle Posted 12/11/07 08:33 AM Share Posted 12/11/07 08:33 AM (edited) Hi Drtyboost,I have (done by Blacktrack not me) the external PSR 52mm wastegate with eboost. As others have mentioned it's not a cheap option.In my opinion the internal with bigger flapper & accuator would have done the job. It does work great. attached is some pic's.Muzza. Edited 12/11/07 08:38 AM by Muzza Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-594991 Share on other sites More sharing options...
dansedgli Member 214 Member For: 21y 4m 28d Posted 12/11/07 09:43 AM Share Posted 12/11/07 09:43 AM Ive seen another one where the wastegate was welded to the collector of the manifold on the top section. Its what the VL boys do. Similar to this setup from JPC: Link to comment https://www.fordxr6turbo.com/forum/topic/39704-external-gate/#findComment-595029 Share on other sites More sharing options...
