Ninka Donating Members 1,850 Member For: 21y 4m 5d Gender: Male Location: Perth, WA Posted 01/11/07 01:29 AM Author Share Posted 01/11/07 01:29 AM Im starting to think the supply screen is a bad idea. Im going to have a bit or a search around to try and find a larger screen that can be remote mounted to make servicing easier.I'm thinking the same, and will remove the screen before fitting the new turbo.A small inline filter on the feed line, in a place where it is possible to get to it would be ideal, so if you come across something suitable, please let me know. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 10m 5d Gender: Male Posted 01/11/07 01:34 AM Share Posted 01/11/07 01:34 AM the oil line does go right around the front of the block, in plain view, so why the screen is buried under the intake manifold is beyond me. I am also very interested in a different setup luke, so please let me know too.cheers Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 01/11/07 02:34 AM Share Posted 01/11/07 02:34 AM the oil line does go right around the front of the block, in plain view, so why the screen is buried under the intake manifold is beyond me. i am also very interested in a different setup luke, so please let me know too.cheersJust been having a quite looksee and have found this stuff from earls that might fit the bill.http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.holley.com/165106ERL.asp-4an is aprox 6mm and -6an is 10mm so the -6an filter with the -6an to 3/8 adaptors would probably work well. You could cut the supply like and install this on the front of the engine where the oil feed lineruns across the timing cover. In sure it would be very easy to rig up some sort of mount and clamp setup to support the filter. It would be very easu to access and service if it was mounted there. Link to comment Share on other sites More sharing options...
FLASHXR Donating Members 135 Member For: 18y 7m 16d Gender: Male Location: Sydney Posted 01/11/07 04:38 AM Share Posted 01/11/07 04:38 AM (edited) You didnt by any chance blow an intake hose off recently Ninka did you? Snapped shafts can also be a result of a turbo over rev. I have a lot of customers experience the same thing generally within about 2 weeks after blowing a hose off... Edited 01/11/07 04:39 AM by FLASHXR Link to comment Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 17y 10m 7d Gender: Male Posted 01/11/07 05:50 AM Share Posted 01/11/07 05:50 AM WOWSERS!bad luck mate! hope it doesn't cost too much to sort out! Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y Gender: Male Location: central coast Posted 01/11/07 07:06 AM Share Posted 01/11/07 07:06 AM probably the best idea iv'e heard of on this site great work guys keep us all up to date on what you come up with I'm still saving for a trans so experamental work like this I can't afford at the moment Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 19y 10m 19d Posted 01/11/07 07:23 AM Share Posted 01/11/07 07:23 AM Feel ya pain mate, just replaced the bearings on mine after 97k. In my case the pick up pipe itself was blocked like a chainsmoking, McDonalds junky's artery.All the best with the make good Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 01/11/07 09:57 PM Share Posted 01/11/07 09:57 PM Just been having a quite looksee and have found this stuff from earls that might fit the bill.http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.holley.com/165106ERL.asp-4an is aprox 6mm and -6an is 10mm so the -6an filter with the -6an to 3/8 adaptors would probably work well. You could cut the supply like and install this on the front of the engine where the oil feed lineruns across the timing cover. In sure it would be very easy to rig up some sort of mount and clamp setup to support the filter. It would be very easu to access and service if it was mounted there.Got a reply back from the supplierThe filter screen assembly is $61.88 and the two fittings required to install it are $41.25. so for a little over a hundred bucks it may turn out to be a good solution.luke Link to comment Share on other sites More sharing options...
blobak Member 75 Member For: 17y 9m 3d Gender: Male Location: them there hills Posted 02/11/07 10:32 AM Share Posted 02/11/07 10:32 AM Got a reply back from the supplierThe filter screen assembly is $61.88 and the two fittings required to install it are $41.25. so for a little over a hundred bucks it may turn out to be a good solution.lukeAny chance of finding out the micron rating of the filter? Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 4m 5d Gender: Male Location: Perth, WA Posted 02/11/07 01:34 PM Author Share Posted 02/11/07 01:34 PM You didnt by any chance blow an intake hose off recently Ninka did you? Snapped shafts can also be a result of a turbo over rev. I have a lot of customers experience the same thing generally within about 2 weeks after blowing a hose off...No hoses blown off.Got the 'new' turbo back today, complete replacement of everything except the exhaust and compressor housings A BIG thank-you to a member here, who has been extremely helpful in getting my turbo fixed quickly :sniffle: On further investigation today, I have found that NO oil is coming through the feed line with the engine running for a minute or so, so it is well and truly blocked.Will pull it apart tomorrow, and should then have a better idea what may be causing this, but I did clean the screen less than 10,000k's ago, so it is a bit of a mystery. Link to comment Share on other sites More sharing options...
