AGENT ORANGE F6 Phoon ----- MISH!! Member 348 Member For: 17y 2m 4d Gender: Male Location: BRISBANE Posted 22/11/07 02:21 AM Share Posted 22/11/07 02:21 AM Has anyone changed the setup to an inline filter in a different location yet? Im not exactly sure where to look for the fitting with the screen in it? and am curious to know where it is and how hard it would be to change the setup from current to the new one. Link to comment Share on other sites More sharing options...
2fardown Member 526 Member For: 18y 11m 13d Gender: Male Location: Brisbane Posted 22/11/07 04:17 AM Share Posted 22/11/07 04:17 AM I'm contemplating getting rid of the filter all together. I'd rather have some small particles get through then no oil at all... Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y Gender: Male Location: ACT Posted 22/11/07 04:55 AM Share Posted 22/11/07 04:55 AM (edited) I'm contemplating getting rid of the filter all together. I'd rather have some small particles get through then no oil at all...I just did a search and found this:Stainless steel oil feed line. This is a setup for the Garrett GT Center sections and pulls oil from the head because Garrett CHRA's only prefer 50-60 pounds of oil pressure. The filter is a secondary device that helps filter the oilThis filter works great but it must be checked with EVERY OIL CHANGE because the filter could become over clogged if you never check the filter element, it makes sense that you change your engine oil filter with every change so make sure you examine the filter as well! Edited 22/11/07 05:01 AM by f-wolf Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y Gender: Male Location: ACT Posted 22/11/07 05:14 AM Share Posted 22/11/07 05:14 AM And from the UK we got this.These in-line pre-filters have a 25 micron stainless steel gauze filter which stops debris from entering the delicate internals of your turbo, greatly reducing bearing wear. Suitable for fitment to Garrett T3, T3.5 or T4 turbos with 1/8" BSP fittings. Popular fitments; Cosworth range, Escort, RS Turbo etc..Polished silver. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 22/11/07 05:31 AM Share Posted 22/11/07 05:31 AM Just been having a quite looksee and have found this stuff from earls that might fit the bill.http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.fluidsystemsengineering.com/par...t=50&page=1http://www.holley.com/165106ERL.asp-4an is aprox 6mm and -6an is 10mm so the -6an filter with the -6an to 3/8 adaptors would probably work well. You could cut the supply like and install this on the front of the engine where the oil feed lineruns across the timing cover. In sure it would be very easy to rig up some sort of mount and clamp setup to support the filter. It would be very easu to access and service if it was mounted there.I just did a search and found this:Stainless steel oil feed line. This is a setup for the Garrett GT Center sections and pulls oil from the head because Garrett CHRA's only prefer 50-60 pounds of oil pressure. The filter is a secondary device that helps filter the oilThis filter works great but it must be checked with EVERY OIL CHANGE because the filter could become over clogged if you never check the filter element, it makes sense that you change your engine oil filter with every change so make sure you examine the filter as well! Link to comment Share on other sites More sharing options...
AGENT ORANGE F6 Phoon ----- MISH!! Member 348 Member For: 17y 2m 4d Gender: Male Location: BRISBANE Posted 23/11/07 05:53 AM Share Posted 23/11/07 05:53 AM Can anyone post a photo of where to find this this oil screen filter and what is needed to remove it to check its condition, is it under the intake manifold someone was saying maybe???? Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 21y 4m 2d Gender: Male Location: Brisbane Posted 23/11/07 06:21 AM Share Posted 23/11/07 06:21 AM This should help:http://www.fordxr6turbo.com/forum/index.php?showtopic=32461 Link to comment Share on other sites More sharing options...
AGENT ORANGE F6 Phoon ----- MISH!! Member 348 Member For: 17y 2m 4d Gender: Male Location: BRISBANE Posted 23/11/07 06:30 AM Share Posted 23/11/07 06:30 AM Thanks mateappreciate it. hopefully its straight forward enough, its hard to no whether to go an external style or just get a new inline filter. Have you done your F6 yet? Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 4m 1d Gender: Male Location: Perth, WA Posted 11/04/08 02:39 PM Author Share Posted 11/04/08 02:39 PM (edited) I guess there will always be small particles of impurities in the engine oil, but I doubt it would be sufficient to damage the bearing in the turbo, and a slightly noisy bearing is better than a total failure because the screen gets plugged.The problem is that the screen is way too small, and located in an area where servicing is really difficult, so an alternative filter would be a good insurance measure, though not an absolute necessity.I know it's been a long time, BUT I finally got the bits and pieces together, and the new inline oil screen is now sifting my oil on its way to the turbo.Pretty neat setup I thought Edited 11/04/08 02:40 PM by Ninka Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 16y 10m 11d Gender: Male Location: Nrth Qld Posted 11/04/08 09:04 PM Share Posted 11/04/08 09:04 PM Whats that top pipe for? So this filter, where/what/$$$??????? Link to comment Share on other sites More sharing options...
