Phoon Down On Power
Featured Replies
#11
9.5... ill give u a drag :blink:
  • Replies 22
  • Views 5.5k
#12
I'm suprised it's not coughing and spluttering with all that fuel , running rich as.As others have said sounds like you have larger squirters. Out of curiosity what boost is being achieved??
3" zorst will flow less than the stock twin 2.25
Mate seems like a custom tune is required, Capa (Martin aka Street Tuner)or KPM motorsport site sponsor. Give 'em a call they should be able to sort you out and get that lost 60rwkw back for you
#13
  • Author
a mate who knows kpm is getting a price for me, Rang Morpowa and they said it wldnt be worth putting a tune in until things are fixed , The tuner at aussie dyno told me this as well ,, im guna have to check the dump pipe cos it may be 3.5
boost was about 7-8 psi if im reading the above sheet correctly.
whats the easiest way to see what injectors its running
Edited by redghia
#14
maybe a collapsed cat.
This would be my first place to look. Running that rich, the cat will be well and truly rooted.
I rooted a cat (not literally!) in under 2,500 klms becuase of running rich.
Cheers
Dan
#15
  • Author
I had my thoughts about this and it wld be restricting power quite a bit. havnt heard any rattles though. would have fouled the Oxy sensor as well
#16
what colour are the injectors? do yourself a favour and buy a flash tuner from kpm with their $495 special and then give street tuner a call and get it on a dyno with someone who knows these cars
#17
does it idle properly? if it doesn't then its a good bet the injectors have been upgraded without a tune...
#18
was speaking to a mechanic during the week about getting an exhaust put on and he said if you whack on a full exhaust straight onto these cars they will run really rich and would require a tune. This might be all you need *shrugs*
#19
Just check the part number on the injectors and compare with a stock XR6 T or typhoon....
#20
:roflmbo: Don't think fitting a full free flowing exhaust will make it run rich , I would have thought quite the opposite
Recently Browsing 0
