Do I Need To Retune With A New Cat
Featured Replies
#1
Hi Guys,
Just got my xr6t ute wohhhoooooo. Its a BA manual. It has a generic tune and a process west fmic. Im thinking of changing the cat but am unsure if I need to retune it. It sounds like I do looking at these posts but would like to know 100% and if I do who do I take it too.
Thanks
#2
Why are you changing the cat?
Oh and congrats :stirthepot: What colour?
Edited by tab
#3
  • Author
Just reading all these threads and id say its holding me back. It got tuned and pulled 249kwatw (so the seller said)
Its citric acid in colour
#4
While changing the cat for a high flow unit will help, the standard injectors will your first item that will limit power. Valve spring may be a issue but every car is different for these.
Standard Injector limit 260kw approx
Standard Cat limit 300kw approx
Edited by seventytwo
#5
I wouldn't drive very long with a CAT swap over with out a retune.
Mine over boosted like a mofo.
I'd get injectors and a CAT then get it re tuned and would get rid of that generic tune.
#6
BF standard cat limit.. 267rwkw :stupid:
#7
  • Author
Im only looking for approx 280kw so ill do the injectors first then and may even leave the cat.
Do I need to retune the car after I put the injectors in?
#8
I just replaced the standard cat last week and it sent my existing 10psi tune to over 13psi before I backed off. Now with the standard tune in it goes to 7psi-(custom tune next week).
Take your new injectors with you to the tuner asap for a custom tune.
#9
A big YES to both.Why not save a little bit more and get them both done at the same time,then retune. :stupid:
Edited by velociTy
#10
  • Author
I will do that, makes more sense that way.
Do you think I will need valve springs before the tune or are the factory ones ok?
Any reputable tuners down Wollongong way if not who do I see in Sydney and what would a tune set me back?
Thanks for all your help guys, the bug has bitten and wont let go :stupid:
Recently Browsing 0
