RAP1D Member Legacy Donating Member 3,739 Member For: 20y 4m 8d Gender: Male Location: Sydney NSW Posted 05/05/07 03:56 AM Posted 05/05/07 03:56 AM Yeah it can be used with any IC piping that comes up from the passanger side... so under headlight, you just cant have a factory airbox or large battery sitting there
dalts Member 755 Member For: 20y 4m 2d Gender: Male Location: brisbane Posted 05/05/07 06:08 AM Posted 05/05/07 06:08 AM whats the cost of the nizpro one? It could be made to work with any other intercooler/intake setup couldnt it?around $1700,and you can get your owns pipes manufactored from any fabrication shoplee
illusionzzz Member 180 Member For: 20y 9m 14d Posted 05/05/07 06:36 AM Posted 05/05/07 06:36 AM thanks guys! might stick with the stock one!
JP300 Legacy Donating Member 842 Member For: 21y 15d Gender: Male Location: Sydney Posted 05/05/07 06:48 AM Posted 05/05/07 06:48 AM I had 360 rwkw and a lot of the guys on the forum run more than this without and problems ...I swapped it out for the Nizpro to improve throttle response and it works a treat. Soft 14psi tune provides 820 nm @ 3000 rpm and we have seen as much as 1100 nm @ 3000 rpm with higher boost !!
DAWSEY Member 441 Member For: 20y 9m 18d Gender: Male Posted 09/05/07 12:28 PM Posted 09/05/07 12:28 PM every nitto one I have seen or heard of have split (3 that I have seen)I am holding out to see the plazmaman and progress west cooler. but the nizpro looks the goods at this stage
KW CONNER Member 52 Member For: 19y 4m 29d Location: Cessnock Posted 09/05/07 03:49 PM Posted 09/05/07 03:49 PM every nitto one I have seen or heard of have split (3 that I have seen)I am holding out to see the plazmaman and progress west cooler. but the nizpro looks the goods at this stage I had my heart set on a Nitto plenum , had the money ready , but apparently Hypertune the builder of the Nitto plenums are having big problems with all their plenum ranges cracking . Some Honda civic one didnt even fit under the bonnet by 2 inches . My mate was pissed when his cracked . C&V ( Con ) replaced it but . One of the others is the go , cant wait to see Kevins finished , and Plazmamans hopefully will be a work of art again . Then maybe Nizpro . I dont know which way to go though . Which way are you guys leaning ???
Gavin.K Member 288 Member For: 21y 3m 15d Gender: Male Location: sydney Posted 10/05/07 03:32 AM Posted 10/05/07 03:32 AM The boys at Hypertune have had problems but thay have fixed it with a design change. I can not say anything about the honda version but they do stand behind there product.
Billsta Member 355 Member For: 20y 2m 23d Location: Rolling on my 20's Posted 10/05/07 04:57 AM Posted 10/05/07 04:57 AM I've got the Nitto plenum, the series 1 were the one that cracked including one I had on my car.I've now got a series 2 with design changes and it's an awesome unit that looks and works well.
HYPERTUNE New Member 1 Member For: 19y 7m 5d Posted 14/05/07 09:33 AM Posted 14/05/07 09:33 AM I had my heart set on a Nitto plenum , had the money ready , but apparently Hypertune the builder of the Nitto plenums are having big problems with all their plenum ranges cracking . Some Honda civic one didnt even fit under the bonnet by 2 inches . My mate was pissed when his cracked . C&V ( Con ) replaced it but . One of the others is the go , cant wait to see Kevins finished , and Plazmamans hopefully will be a work of art again . Then maybe Nizpro . I dont know which way to go though . Which way are you guys leaning ???Regarding the NITTO manifolds, the problem of cracking was caused by an incorrect machining process (wrong radius cutter used for the plenum base) making a section of it too thin. ALL the plenums have been replaced with a correctly machined part, eliminating any problems. Gavin.K knows EXACTLY what I'm talking about (he is somewhat of a guru when it comes to CNC machining, but don't tell anyone I said so Also, regarding the Hypertune honda manifolds, these are actually an S2000 part, and a couple were fitted with a flange for a stock TB at the request of our US distributors (we told them there would be clearance issues, but they said they could make it work..... ) This caused us some dramas (should have known) but has been resolved also (plenum is only offered per the original design now ) )Oh, and to Gavin.K and Billsta, thanks for the support!!!
01txr Member 861 Member For: 19y 8m 14d Gender: Male Location: QLD Posted 14/05/07 10:09 AM Posted 14/05/07 10:09 AM So how much can you do me a plenum for to fit my 2003 XR6 Turbo.I will make up my mind on which plenum to buy once Process West and Plazman finalise there price.And do you do any other parts for the XR6 Turbo.
