F6 RAPID Formerly Turbo6 Legacy Donating Member 2,332 Member For: 23y 8m 20d Location: North Brisbane Posted 07/04/07 06:02 AM Posted 07/04/07 06:02 AM I have 9.5" wheels on the rear in 20's - 275/35-20 to be precise. It makes it a little over-geared but it has enough power to turn the wheels.
Evil F6 Legacy Donating Member 830 Member For: 20y 8m 19d Gender: Male Location: Sydney Posted 07/04/07 06:55 AM Posted 07/04/07 06:55 AM I have 19x8.5" front and 19x9.5" rear wearing 245/35 and 275/35 respectively. I was never going to run the same width tyres all round. I'm disappointed that a car as big as the ford couldn't get 19x10.5 under the rear, I wanted 295/35 on the back.
Ninka Legacy Donating Member 1,850 Member For: 23y 9m 5d Gender: Male Location: Perth, WA Posted 07/04/07 07:08 AM Posted 07/04/07 07:08 AM 245/35-19 on the front - 275/30-19 on the rearsPhoto attached
Paranormal Member 469 Member For: 23y 1m 4d Location: Brissy Posted 07/04/07 07:29 AM Posted 07/04/07 07:29 AM I'm running 18x8.5" rims and used to run 235 front and 265 rear. Both sizes turnout to be a bit wrong, the 235 on front were a little small with the rim protector part of the tyre slighty inside the width of the rim thus a couple of nicks in the left front rim and the rears running 265 always felt like the rear was squiriming and wringling around a lot , which is cool changing gears etc but I ended up chewing out the insides of the tyres as a result, and worn thru the rears more than 2x as fast as the fronts, so I have now gone to 245x40x18 all round and will be rotating. Just my situation but 9.5" rims would be nice however to rotate has anyone tried 265-275's all round? is it possible and much does running wide rubber on the fron affect things?
tquarrell Member 181 Member For: 22y 1m 25d Gender: Male Location: Sydney, NSW Posted 07/04/07 07:55 AM Posted 07/04/07 07:55 AM I've got that stock 18x8" rims and have fitted 235 bfg's all round (235 $245ea, 245 $345ea, that's the only reason). I think the quality of the tyre is more important than the size and my 235 bfg's have 1/2" wider tread face than the sp9000 245's and about 1" more than nankang ns2's, so not all tyres are the same despite thier stated size. Of more importance is the quality of the rubber obviously.Traction in the dry is pretty good. You obviously can't just stomp on the throttle, but with some decent throttle control it is possible accelerate quite rapidly (can't use full throttle in first at any speed, but). And besides, I think you're better off loosing traction than breaking gearboxes and cvs with to much traction. It's more fun to drive and traction control is always there for the wet or if you want a pretty mundane drive.
AGENT ORANGE F6 Phoon ----- MISH!! Legacy Donating Member 348 Member For: 19y 7m 7d Gender: Male Location: BRISBANE Posted 07/04/07 08:09 AM Posted 07/04/07 08:09 AM I Have same widths as Black thunder, they look tuff form behind, an the dish really suits the T's I rekon.
turbo_nick some guy... Member 277 Member For: 23y 11m 15d Posted 07/04/07 08:30 AM Posted 07/04/07 08:30 AM Just my situation but 9.5" rims would be nice however to rotate has anyone tried 265-275's all round? is it possible and much does running wide rubber on the fron affect things?265/275s are too wide for the front, and 9" rims are not legal on the front either.
cobrav8 Member 1,969 Member For: 21y 6m 5d Gender: Male Location: New Zealand Posted 07/04/07 08:31 AM Posted 07/04/07 08:31 AM pfft - 275sThe Cobra has 17x12 rears with 315s and fronts are 17x10 with 255s
kramo Member 163 Member For: 23y 1m 12d Gender: Male Location: Melbourne Posted 08/04/07 02:06 AM Posted 08/04/07 02:06 AM Has anyone successfully fitted 285/30 R19 on 9.5 inch rear rims?Obviously you would need to roll your guards, but wondering if you could fit them in?
turbo_nick some guy... Member 277 Member For: 23y 11m 15d Posted 08/04/07 04:31 AM Posted 08/04/07 04:31 AM Has anyone successfully fitted 285/30 R19 on 9.5 inch rear rims?Obviously you would need to roll your guards, but wondering if you could fit them in?Yup, a guy in QLD found the right combo. 19x8.5 with 245/35R19 front and 19x9.5 with 285/30R19 rear. Both front and rear run a +35 offset with 1 degree of negative camber on the back and rolled guards.
